  • Revolver Gunsmith Tool
    Took me a few weeks to read through the projects posted; what a pleasure! If this has already been posted, it's in a dead photo link from my end.
    Here are a few gunsmith specific tools I made when learning the manual lathe.
    As you can see, simple tool for holding the fragile revolver cylinder ejector rod for unscrewing from the cylinder (left hand thread).
    This project and a few more were the cause of my love affair with Hardinge toolroom lathes.
    • Gun Sight Pusher
      Another machining class project-see different pushers for rear and front sights
      • Nice work on those tools, they look good. The engraving is very nice, was that done on a CNC mill?
        • Originally posted by Yondering View Post
          Yes, Engraved later on, as I gained access and experience with CNC machines.
          • Everybody Gotta make a hammer, No?
            • nice work.
              • Originally posted by nc5a View Post
                I was really hoping no one would ask that. The two previous toe jack lifting toes were not attached or pinned to the jack lifting pad nor were there guides on the side of the toe fixture to keep it from shifting sideways.
                I copied mine from one madman made, and he had a really good idea on that attachment point. unscrew the acme thread as far as it will go. Hacksaw it off with say a 1/4 or 3/8 still sticking out. in that stub-sticking-out, hacksaw a screw driver slot and screw the stub in all the way to the bottom. Then use the cut off part is the bolt to hold the thing together.
                Its not as pretty as the one above, but is one of the more useful things I've made
                located in Toronto Ontario
                • Rifle Receiver wrench
                  Working on quite a few Winchesters
                  • shopmade anvil
                    my shopmade anvill:
                    greetings from Brazil
                    • Originally posted by celsoari View Post
                      my shopmade anvill:
                      Very nice and a LOT of work!
                      • Shameless copy of commercial product, as posted about here:
                        Scribed lines
                        Punch centered on lines - the wonkiness is a matter of camera angle:
                        In high school shop class 60 years ago, my biggest weakness was drilling holes where they were supposed to be. It's still a challenge for me. I'm hopeful that this punch will help.
                        Parallax is pretty much a non-issue with the punch's lines being scratched on the bottom.
                        The lines were scratched by a carbide scribe held in the mill. I wasn't real careful on the lathe about keeping the top and bottom surfaces parallel, so it was difficult making the scratch depth consistent - some fiddling involved. I'll know better next time.
                        • Very nice. What kind of plastic is that?
                          • Originally posted by RichR View Post
                            Acrylic, aka Plexiglas. I think - it's something that I found at our dump, so I'm not positive.
                            • I wonder if there's a way to keep the bottom from getting scratched with use.
                              • Whats the business end look like? Is it just a punch. Looks clumsy to use.
