  • Originally posted by mattthegamer463 View Post
    I wonder if there's a way to keep the bottom from getting scratched with use.
    Acrylic is comparitively hard for a thermoplastic.
    One could use 3 pieces of tape on the bottom to form a tripod a few thousanths thick in order to keep the base off the working surface.
    Bill Pendergrass
    Rotec RM-1 w/Rusnok head
    Atlas TH42 QC10
      Make one from sapphire optical flat
      • Make one from sapphire optical flat
        Could be interesting - sapphire has a Mohr hardness of 9.
        Yes, you can machine it with diamond tooling, but slowly and under water.
        Cheers
        Roger
        • Iphone screen protector gorilla glass. Still need diamond to cut it without shattering probably but it already has an adhesive on it.
          • Just use a diamond.
            • Originally posted by garyhlucas View Post
              Find a friend with a waterjet to cut you a 'donut' of gorilla glass.
              • My import boring head has both inch and metric screws. Kind of annoying. I took an old Ironhead Sportster pushrod and made this T-wrench so I have the right ones at hand.
                My Craftsman 6x18 is currently in storage. There are times I still want to use those little chucks and faceplates. I took a 1” bull plug and made this 1x10 adapter so I can chuck them up in the 8” chuck on my ENCO.
                Illigitimi non Carborundum 😎
                • Originally posted by plunger View Post
                  Whats the business end look like? Is it just a punch. Looks clumsy to use.
                  I don't know what Bob's would be like to use, but the optical punch from Grizzly works great for me.
                  This Optical Punch Set is indispensable when doing critical layout work. Just look down the magnifying lens and align the cross hairs with the mark on your work piece. Replace the magnifier with the supplied punch and give it a tap. Includes a bull's eye and cross hair lens, a 150 degree and 60 degree center punch and plastic case.
                  • [QUOTE=Tim The Grim;1199308]My import boring head has both inch and metric screws. Kind of annoying. I took an old Ironhead Sportster pushrod and made this T-wrench so I have the right ones at hand.
                    For the sake and mental health of Sportster pushrods worldwide, i hope the pushrod was already damaged or bent prior to your modification.........
                    nice work by the way...
                    • I've got some from a Norton if you need Whitworth.
                      Len
                      • Originally posted by QSIMDO View Post
                        Naah, it'd vibrate too much & be too slippery from the oil leaks to tighten anything!
                        • Originally posted by DICKEYBIRD View Post
                          Yeah, but it would be classy while it did that. After all, it's a Norton!
                          Dan
                          • Originally posted by danlb View Post
                            Dan
                            And it would go round corners and have decent stopping distances.........
                            • Originally posted by thaiguzzi View Post
                              Yeah but it wouldn't look as good.
                              Lewis Grizzard
                              • Originally posted by Dave C View Post
                                Hard to tell what kind of motorcycle it is with that picture.
