Why not? But you probably want side handle unless your arms are like Popeye's
If I have plenty of holes to tap I'd rather do it with anything else than manual twisting.
See for example https://www.amazon.com/Stanley-5044-.../dp/B0001IW8N8
And there are plenty of older ones available second hand on ebay.
One caution: check which sort of chuck the brace has. Some of them may have 'drill chucks', which slip and are useless, but others have a chuck designed for holding a square shaft - like the end of a tap. I think all the old ones have this.
I took a hex extender and converted the male end to have 4 flats rather than a hex fitting. Now I can use a brace on any of the common hex inserts: really useful for getting rusty bolts and screws out (or snapping them off...).
When using one of these you get massive torque, but really controlled torque. You can sense a small increase in tapping force and stop in a few degrees.
OK, somewhere around M12 things might get a bit difficult - but still less difficult than any other method (apart from thread milling on a CNC).
Cheers
PS: I have three braces, of different vintages.
