Any other ideas for keeping a diamond wheel (not lapidary disk) wet enough while grinding? How wet do they have to be?
Originally posted by challenger View PostAny other ideas for keeping a diamond wheel (not lapidary disk) wet enough while grinding? How wet do they have to be?
I use an aquarium pump with a tray underneath to catch the water.Vitَria, Brazil
- Likes 2
Stefan has a great video on building a machine using the lapidary discs: https://www.youtube.com/watch?v=GOBt...1jFWw&index=14Milton
Originally posted by ATW View PostI wanted some physical stops on the rotary table...
The one possible drawback I can see, is what happens when you want the stop at/near one of the T-slots - oh well that will be a project for another day, maybe need to make some wider stops for those occasions.
I like to use a 1/16" or 1/8" pipe tap and plug for that type of application, as they are tapered and expand more the further you screw them in. Then you can just make the part to a close slip fit, drill and tap, then make the slit.Kansas City area
- Likes 1
It's mainly to keep the heat DOWN, and to clear away the grindings.
I flood the diamond cutter as you can see. That seems to be enough.
But then I have to drain all the dust out of the tank, which requires a bit of flow. The drain is not visible in this photo.
The basalt comes from the local railway yards: ballast off the side of a shunting line.
Clear surrounds so I can see what is happening.
Cheers
Roger
Hi Jim
What am I making?
Well, drilling ruby balls was to see if I could make my own stylii for touch probes. The answer was yes.
Machining basalt was to see if I could. The answer was yes.
The shapes were mathematical 'things' just to see if I could.
These are wood prototypes prior to machining basalt. I doubt they serve any useful purpose, but I am a retired research scientist, I have a (solid) CNC mill, I write my own programs in g-code and I can handle the maths involved. Does that explains things? Maybe not ... 😊
I haven't done much with basalt recently as I am making and selling ultra-light high-tech remote inverted canister stoves of my own design for winter mountaineering. That pays better too!
Cheers
Roger
Nice rotab stops idea! I'll have to look at mine to see if the same style would work or if I need to adapt.
Thanks Dickey for the link. I'm half way through watching it with the morning coffee.
That made me go back a bit and realized that I missed the earlier reference by wbc to the speeds. While he gets away with up around 1800 rpm I think a bit slower might be better. Or at least going with a more variable speed setup. Not sure what sort of option yet. But clearly the final honing and polishing is best done at very low speed like 150 to 200 RPM.
And Stefan's magnets in the aluminium disc with drive pins is perfect. I suspect it'll mean the drill only last a couple or three holes even drilling from the back but that's not a big deal to sharpen them.... I can touch them up on the first disc on the machine ! ! ! ! 😁Chilliwack BC, Canada
Re: The cut knurler, from 3 or 4 pages back in time:
Moved on to re-purposing orphaned Phase-II bump knurler into a straddle knurler with some 3/4" scrap square stock.
Clamping rod is positioned to allow up to 2-1/4" diameter stock. 1/4-28 threaded. Geometry such that one turn
of clamp screw closes wheel space down 0.060". Added a pin to spring bore to prevent deformation, then added
a small plate to retain the pin. Ooof. Started down that path because did not have material to make a custom hoop
spring that could wrap around arm pivot bolts. Could not put spring at clamp rod and still get 1/8" to 2-1/4" spring action
without work to the original QCTP base to increase the arm pivot spacing.
Tommy bar an after-the-fact addition...thought it would be easier to crank the knurled knob given I made it so large...
so next time, could use smaller knurled knob with tommy bar, or just a nut.
Easier than cut knurler to set up for the random knurl; more forgiving/self centering; better for small diameter knurl,
at least for a terminal beginner like moi.
- Likes 5
Hi Jim
Do you make the stoves out of titanium?
Ah well, that is a long story, spanning 10 years or more. I am a retired research scientist and a bushwalker. But not being young any more, I yearn for a lighter pack. Also I go ski touring, which can be too cold for the simple little upright canister stoves. What all that means is that I want a remote inverted canister stove, but not one of the rather heavy and clumsy commercial ones. It seemed to me that improvements were possible ... and you know where that leads!
My manual machining is tolerable, but not good enough imho. So I bought a good CNC machine, good to 0.01 mm easily (ie not Chinese), taught myself how to write g-code, and ...
On the left we have my Version 3 stove. It is a 'vortex' burner, and makes a bit of noise. Complex aerodynamics inside.
On the right we have Version 4, with a (fairly) quiet burner. More complex aerodynamics. I have skipped V-1, V0, V1 and V2.
The really hot bits are indeed titanium alloy. There is also some SS mesh on the right. Both use aluminium for the non-hot parts. The handle on the right is carbon fibre tubng. The connection to the canister (out of sight on the left) uses acetal, nylon, PET, Lexan, brass, and there are several Viton O-rings here and there. Eclectic.
Sales are to fellow light-weight bushwalking enthusiasts around the world. I am getting close to 200 so far. Great fun, and I have paid off the CNC!
Cheers
Roger
- Likes 2
