Made some hold down clamps
Enlarging the screw holes a little (1mm larger) in the old chuck, to aid with being able to loosen the screws a little and knocking the chuck around to fine adjust it. Hoping to get some more life out of this worn old chuck that way. The screws where really a tight fit in the bore so adjustment was tricky, now I should have half a mm in either direction.
