I too am easily corn fused picturing rotary broaching at work. Wikipedia may help:
The necessary condition is that the center of rotation of what I am calling the "shank" and the center of rotation of the "wobbling" broach intersect
at the face of the broach. This varies with angle and length of broach. Many designs allow the "shank" to be adjusted relative to the "barrel"
to accommodate differing length broaches. I settled on fixed 1.5" long broaches and then "dial gauge found" the proper shank
offset to get the zero intersection. No math or geometry dizziness. Then screwed the two pieces together and welded for good measure.
Then turned down the frankenstein assemblage into a marginally less crappy looking rounder assembly. Beauty, it ain't.
As noted before, a mill, lathe, or drill press, etc. may be employed. Rotate the tool, or rotate the toolee, no matter.
