Yeah, this was an inexpensive imported chuck that I have found useful for things like starting thread dies, etc.
That seems much handier than the typical solution of a plug in the end of the tubing that is centered. Or even a bull-nose center, since they are great, but always the wrong size for what is wanted.
Good idea, one I never considered.2801 3147 6749 8779 4900 4900 4900
It's just a box of rain, I don't know who put it there.
Unfinished gang tool holder for an old CNC lathe, one more hole to be drilled and reamed then the set screw holes drilled and tapped.
Left handed boring bar for light facing and OD turning, drill, bore then an internal retaining ring groove tool (not shown). Give each tool a number and then touch them off, write the program and have at it, do not call the wrong tool number at the wrong time as this makes for spectacular crashes (-:
The parts were POM so it did not have to be very rigid.
- 1 like
Precision drilling jig for a simple little lathe.
The cross saddle provides one axis and the aluminium optical slide with brass knob provides the other axis, to align to the real centre of rotation of the chuck.
With this I can routinely drill 0.3 mm holes in stove jets by using the main feed wheel. So far, having drilled >100 jets, I have not broken a single drill bit. These days I don't even bother using any sort of centre drill first. But I DO use a head mounted magnifier to see what I am doing. The Swiss drills are excellent.
Cheers
Roger
PS: my avatar pic is the same as this, but smaller.
- 5 likes
Originally posted by rcaffin View PostSo far, having drilled >100 jets, I have not broken a single drill bit.
If you're at 0.3mm you're also in 3D printer nozzle territory... although it's probably hard to justify making them rather than buying them.
Originally posted by rcaffin View PostPrecision drilling jig for a simple little lathe. ...
With this I can routinely drill 0.3 mm holes in stove jets by using the main feed wheel. ...
For us colonials, that's less than 1/64". Totally out of the realm of my experience.
How is the drill fed? Surely not with the carriage.
3D printer nozzles? Hum - thank you. I will investigate that. Mine are for an ultra-light inverted winter canister stove I make and sell internationally. Very specialised.
The nozzle does not have to be 0.30 mm: it can be 0.29 mm or 0.31 mm. There IS a difference in performance.
How is the drill fed? Well, it depends on the mood of the moment. I have indeed used the carriage - but with a head-mounted magnifier for control. I have also used the fine feed on the carriage, with careful alignment of the feed. I still use the head-mounted mag.
The blanks are made up on a CNC, with jigs. That means I can hold the thickness of the drilled region of the tip to about 0.3 mm, which is on a par with the diameter of the hole. So the drill bit does not have to go in very far. I think it can manage about 3 mm depth, so 0.5 mm penetration (with overshoot) is simple. I DO make sure there is no pip in the middle from the rest of the machining.
Watching under magnification a 0.3 mm drill bit go in and produce a fine spiral of brass from the flutes is fascinating. Wondering how in Hades the Swiss ground the flutes is also an occupation: the flutes are polished, btw.
I do have a box of the drill bits, not just one. But you can also buy Dormer drill bits down to 0.30 mm (or less?). None of them are cheap.
The Swiss ones come in steps of 0.01 mm (seriously), while the Dormers come I think in bigger steps.
Cheers
Roger
- 2 likes
Cheers
Roger
Ebay has selection of new chinese, resharpened ones and slightly used ones.
Some examples:
https://www.ebay.com/itm/50-Pcs-0135.../153110154651?
https://www.ebay.com/itm/50-Micro-Ca.../222149673270?
https://www.ebay.com/itm/50PCS-0-1-1.../393036934840?
Western brand name drills are my favourite as the 1/8" shank is also solid carbide. Good for tiny DIY tools after you break the fluted part.
(Cheap chinese ones have steel shank so they don't have second life.)Location: Helsinki, Finland, Europe
Carbide PCB drills: many of them start at 0.035 mm (#80), but a market watch will find smaller ones. I keep an eye on this.
Carbide boring bar: I take it that the bit in the lathe chuck has the offset? I use a TCG instead, but this idea is a good one.
And I note the rag used to keep the carbide dust off the lathe ways: very wise. The dust goes everywhere!
Cheers
Roger
Bother: yes, 0.35 mm, not 0.035 mm. Just checking to see who was watching of course ...Last edited by rcaffin; 03-06-2021, 03:45 AM.
Originally posted by rcaffin View PostCarbide PCB drills: many of them start at 0.035 mm (#80), but a market watch will find smaller ones. I keep an eye on this.
Cheers
Roger
Carbide boring bar: yup, I offset the collet chuck with a piece of shim between one of the jaws or something like that.Location: Helsinki, Finland, Europe
Cheers
Roger
Bother: yes, 0.35 mm, not 0.035 mm. Just checking to see who was watching of course ...Last edited by Dave C; 03-06-2021, 04:44 PM.“I know lots of people who are educated far beyond their intelligence”
Lewis Grizzard
Originally posted by Bented View PostUnfinished gang tool holder for an old CNC lathe, one more hole to be drilled and reamed then the set screw holes drilled and tapped.
I made something similar for my Australian made CNC Lathe, they are very handy and save a lot of tool changes.
