Those ganged tool holders could be handy even on a manual lathe for some repetitive jobs. The end face and then each hole could be made to some equal spacing which would make it easy to dial in the block then advance the cross slide to each position.
Originally posted by BCRider View PostThose ganged tool holders could be handy even on a manual lathe for some repetitive jobs. The end face and then each hole could be made to some equal spacing which would make it easy to dial in the block then advance the cross slide to each position.
Larry
Originally posted by metalfixer View Post
I know that there are MT tailstock adapters that hold tooling but with this block in the toolpost option along with a bed stop the options for OD steps and other features open up a lot of small numbers or repetitive hobby options.
Would it be too much to suggest one of those multi tool tail stock units AND the tool post block AND the bed stop? I think not!Chilliwack BC, Canada
Gang tooling: this is a 4-hole unit with 3 tools in it: outside turning, inside turning, and drilling.
For smaller drill bits the empty hole can take a centre drill bit.
This was made from simple Al bar stock, with the block on the CNC table or saddle and the boring done from the chuck - so naturally everything lines up very well. The visible drill bit is in a custom sleeve of course; a chuck would stick out too far.
Cheers
Roger
- Likes 1
I made these recently.
I direct mount d1-4 spider and outboard spider set for chambering rifle barrels:
A d1-4 direct mount receiver truing chuck:
And a axial/radial floating collet chuck. It floats radially .03" from center in all directions, and axially has a 5° range of freedom. When the outer collar is tightened, it draws the moving parts to center and locks everything, for rigid drilling.
- Likes 9
- Likes 4
Originally posted by Hal View PostKen
Very fine work. You put a lot of thought into design.
I'll have to try making a chuck for my d1-3.
What steel did you use ?
what type of shooting do you do?
Any better pictures of of your logo and how did you engrave your logo?
Hal
I apologize. Last time I looked at this thread, I didn't see your questions.
​​​​​​I used 8620 hot roll steel. For no other reason than I got a deal on it.
I do mostly intermediate range steel shooting. Stuff like PRS.
The logo was CNC milled on a 7x26 3 axis vertical mill, using a 1/32" ball end mill.
It just mounts in a regular double wide dovetail-type tool holder. The follower and the sanvik tool mount side-by-side, kind of like it is displayed. I haven't used it in years but it works best if you size everything in one pass. I had a job where I turned a .500 diameter piece of stock down to .125 diameter for about 2 inches in length. Just set it up, dialed it in, slow feed rate, one pass.Last edited by MaxxLagg; 04-24-2021, 09:32 AM.
