Boring Engine Blocks on a Bridgeport Mill
Here's something I knocked up a couple of years ago to allow me to bore engine blocks on the Bridgeport. Nothing more than a piece of EN32 plate fitted where the slotting head would normally sit which allowed me to mount the 777 Van Norman Boring bar. All the rest on the table is a couple of 8" indexing chucks holding a 2" EN32 ground bar with rings that I turned in the lathe to fit the front & rear main caps.
The job on the table was a Chevy 454 that I bored .027" over then finished to size with the hone for each individual piston. The set up works fine for the amount of blocks that I need to bore in a year and once again shows the versatility of the Bridgeport!
See: http://www.youtube.com/watch?v=rr4zy-x-ZJ4
I appologise in advance for the music, thought it was a good idea at the time?
Here's another pic of a Ford 460 being bored in preperation for oversized pistons & 4.3" stroker crank taking it out to to 521 cu.in or 8540cc. It was topped off with an 8-71 Supercharger & when it was finished it made 790hp & 770lbs/ft on the engine dyno. For a car that is taxed & MOT'd and runs on regular pump fuel it makes for an interesting drive?
