  • Strokersix:
    Second photo (original post), clamps to fit the block half of the crank mains? Or...
    • Russ, Not clamps, just locating off the main bore. With the block sitting on them I added packing and clamps at four corners to restrain the block.
      • tools
        here some shop made tools hobs for worm gear
        SNUCE
        ssnuce
        Junior Member
        • Home made Cutter?
          Hi ssnuce
          Was you cutter machined from a section of all thread with slots cut in the side????
          That is a very slick cutter and I would like to duplicate it.
          Thanks
          Tom
          • acme
            left hand 1 1/4 acme 6- 3/8 slots cut in just below thread depth
            relieved on back side of cutting teeth
            GOOD LUCK SNUCE
            ssnuce
            Junior Member
            • What's that black handle in the front of your lathe, in the picture facing the chuck - is a spindle lock handle?
              • lathe
                it tighten the belts and lock in place
                snuce
                • Originally posted by ssnuce
                  SNUCE
                  Does rotation of the cutter mechanically rotate the gear blank
                  (which is free to turn on its arbor shaft)?
                  The lathe operator advances the gear blank into the cutter using the
                  crossfeed to achieve the desired thread depth, correct?
                  • acme
                    that right it work great
                    snuce
                    • can you cut worm gears in steel that way, effortlessly? I would imagine the harder the material you're cutting, the more backlash the worm gear will have?
                      • A better way to relieve shop made cutters like that is with a ball nose end mill. The curve of the ball nose automatically gives you relief. You have to cut off center to make it work.
                        James Kilroy
                        • SSnuce,
                          Is the acme thread screw as you get it hard enough to cut the steel or do you harden it more after the machining on it is finished? Also, what steel do you use for the gear and do you harden the gear after you cut it?
                          Jack.
                          • Looks like the worm gear is Nylatron to me, not steel. Nice work!
                            Maybe start a new thread for more discussion on this particular tool and gear making? This thread is more for show and tell. Just a thought.
                            Originally posted by Jack F
                            SSnuce,
                            Jack.
                            RKW
                            "Work hard. Tell everyone everything you know. Close a deal with a handshake. Have fun!"
                            -- Harold "Doc" Edgerton
                            • Originally posted by RKW
                              he already did:
                              http://bbs.homeshopmachinist.net/showthread.php?t=46440
                              • Some slitting saw arbors, to fit my 1/2" R8 arbor, made from some dumbbells picked up in a garage sale (for $2).
                                From L to R
                                60x1.0, 60x08 and 40x05mm
