I bought one for the 6" mill vise and liked it. Never saw one for the 4" so I cut one out. The stock was there and therefor cut it out symmetrical, maybe I'll use both hands torquing it up. :-)
I hate swarf, so I made a couple of trays to keep the swarf out of my T slots.
They are held in place by the cutout for the hold down bolt of the vise, and the strip of wood that fits in the T slot. If you don’t want to vacuum them out, you can take them out and brush them out like a dust pan.
I made a couple of light weigh dollies, or skates you might call them. The ones on the left worked OK, then I decided to beef them up.
Then I added sort of a toe jack/fork lift “forks” of sorts. I noticed that once I got one end up in the skate, the other end wanted to scoot off when I tried to pry the end up. Now I can lift the other end under control.
They use nothing but screw pressure (from the silver bolt). There is a vertical bolt in the bottom of the skate that keeps them vertical. And if you tighten the back bolt, it will tilt the forks up. It is strong enough to lift my milling machine.
The photo is an example only. The wheels are a little too small for a milling machine. And the forks are too close together in this example. But if I had to, I could clamp it down with a piece of wood. You get the idea
I made an adjustable spanner wrench. They are a press fit, so you can tap them through the jaws for the length you want.
Hi Everyone,
Seeing Jim's post reminded me of what I did years ago to adjust some motorcycle shocks. Needed the same kind of tool again for a grinder I was working on so here it is:
The proper name may be something else but we use to call these monkey wrenches & they are a dime a dozen.
I now have several in different sizes w/different size pins.
