Thanks for the positive feedback. It was one of the first things I made on the mill, and I just keep making more. I wrote a guide on making one at MAKE: Projects if anyone's interested.
I have got some good deals on magnets here:
Ernie (VE7ERN)
hammer-wrench
My take on the popular drawbar hammer-wrench made from a spark plug socket.
I wanted an oval section handle, so I squished a tube and epoxied it onto a solid section. I keep this one at work. I have a commercial one at home, which I actually like better. It has a fatter, cushier handle and a heavier head. But this one works perfectly well, and is distinctive, so it never winds up in someone else's toolbox.Last edited by Randy; 10-05-2017, 08:50 PM.
these skates are a real space saver, as they make it easy to move my lathe up close to the wall and be able to get it out from the wall when I need to work on it .
I borrowed the idea from a friend and modified it to work with leveling pads and my lathe . it's a little crude but works well .
Rockcombo,
Nice idea on the skates. Thanks for posting it.
I would be very careful when moving it though.
As in very slowly. Lathes are very top heavy and a piece of krud in front of one of the wheels could make for a hazard. Not trying to be too critical but just sayin'.
I recall a guy named Gary from this board that wore a lathe that was lighter than your Monarch and it was not good.
BrianOPEN EYES, OPEN EARS, OPEN MIND
the 10ee is 3500 lbs and bottom heavy, but that said , I made them a bit longer then the width of the machine just to be on the safe side and make sure the floor is clean when moving it , with other lathes you would need to use extra care depending on the center of gravity .
Brice
Rock,
I did notice that the 10EE has a somewhat wide base and would not be likely to tip.
Just more of a warning to those who might use your idea. Most lathes are top heavy.
Originally posted by digrNot much here but fast and simple. Holds a one too six inch mic quite easily, drilled two holes to hold the telescoping calipers that I am using at the time.
I guess that bench vice isn't just for work holding any more.
Here's something else I made today:
It's a standard metric/Imperial/drill/tap chart laminated onto some sheet steel and hung on the wall. Next to it, also on hooks to make it portable, is a magnetic whiteboard that sports a calculator.
They may not be "tools" but they're heavily used in my shop.
