  • Did it work?
    • The tool worked great. So did the lessons from the journeymen.
      My dad was one of them.
      • Brain, I can see the device clearly, but for the life of me I can not see how it would be used to remove a plug. Can you provide a little more narrative insight on how it was used? Thanks in advance. -John
        • Originally posted by biometrics
          Bio,
          The old VW beetles had a pipe plug in the transaxle that had a 17mm female hex in it. Slide the male hex on the tool into the plug and use a screwdriver through one of the holes to turn the plug out.
          • I made one of those for Hewland transaxles which use the magnesium VW case, or a stronger copy in aluminium.
            Mine is just a metric bolt head welded to a bar.
            Paul Compton
            www.morini-mania.co.uk
            • Originally posted by bborr01
              Bio,
              That's really interesting to me - I wrench on the newer watercooled VWs (Golfs/Jettas/Sciroccos, etc) and they have the same type of plugs in the transaxles.
              Max
              http://joyofprecision.com/
                Bio,
                When I wrenched VWs I did something similar by welding a 17mm bolt to a 1/2" socket. Not as elegant, but at the time I had access to a welder and not to machine shop equipment.
                Randy
                Do yourself a favor and see if your TV carrier has America One News Network (AONN). 208 on Uverse. It is good old fashion news, unlike the networks, with no hype, bias or other BS.
                • Thanks, Brian, I will have make one for my 68 Bug. I used a 17mm bolt and Vice Grips last time.
                  Oregon Coast
                  • I should think the head of a 17mm bolt would much too large.....
                    I spent most of my money on women and booze, the rest I just wasted.
                    • One thing for shur here is,,,,,,no matter what you say or post, some smart a$$ is going to find fault with it. Just so you can understand, I used a bolt with a 17mm head on it.
                      Oregon Coast
                      • Lugnut. Find fault? Not here. It worked that is all that matters.
                        • Originally posted by lugnut
                          Nah, you gotta cut Fixer some slack, being a Canuck he just doesn't understand good old American metrics...
                          • Saw Stock Stand
                            Here is a stand that I put together out of scrounged materials. The clamp screw is made from a short piece of 3" pipe, a 1/2" bolt and 3 pieces of 1/4" rod. Also re-purposed a worn out brake rotor.
                            edit: I am adding a picture of a modification of the stock stand. I found that it needed a roller so it didn't tip when stock was pilled along the top of it. All scrap stuff that was laying around.
                            Modified Top
                            • it seems you fabricated the red wheel.
                              • Expedient! What's the base from?
                                Chris
