Band saw hydraulic damper
Hi
I just posted this on the 4x6 bandsaw forum, but some of you guys and gals might be interested.
Got sick of breaking teeth of my blade when cutting thin stuff so added a hydraulic damper, and it works beautifully. Simply bought an ebay trailer brake master cylinder and mounted it at the back of the saw.
The saw's base is slotted angle (Dexion) but it is a bit flimsy, so a base of 50x50 RHS was used to support the cylinder. Note the guide to keep the cylinder's push rod horizontal and the 'extendable con rod', the damper only works when the con rod is fully closed, ie as the blade approaches horizontal.
The hose is squashed to control the speed that the saw drops, I'll make a prettier one of those one day when I need my clamp back! The clamp needs to be close to the cylinder.
The hose needs a one way valve in it, so I made a Bunsen valve, screwed a 6mm bolt into the hose to blank it off, then stabbed the hose with a box cutter. I knew there was a reason to study chemistry in the 60s. The hose is looped straight back into the reservoir.
Does it work? Look at the thickness of the metal and the size of the teeth on the blade, and I didn't loose any (more) teeth. I'd say that's a YES!
Hope someone else finds it useful. The quality of the workmanship fits my nom de plume.
Alan aka The Feral Machinist
Hi
