Creativity and field expedience
  • Creativity and field expedience
    My friend retired when he was 70, he is now 81.
    I think he had already entered the first stages of Alzheimer's.
    I'm 69 and hope I have not started.
    I went to visit him today at the Alzheimer's care center and he was very intently feeling the texture of the hand rail and using a Tootsie-Pop stick like a surface micrometer, to check every surface.
    His mind may be lost but he is still working.
    It sounds like the wires are hooked up but the insulation is failing.
    Tough situation. I hope they find a cure for that before I get close to
    worrying about it with myself. The best thing you can do is just be a
    friend and spend time with him when you can.
    --Doozer
    DZER
      Old
      First, define "elderly" and then look up "Geriatrics".
      http://en.wikipedia.org/wiki/Elderly
      http://en.wikipedia.org/wiki/Geriatrics
      http://en.wikipedia.org/wiki/Senescence
        Alzheimer's is not the only type of dementia that afflicts the elderly. First, old age does not cause dementia directly. The risk factors are several and include overweight (3 times increase), disuse of your brain (watch TV), poor diet (see overweight), lack of exercise and surprisingly, poor attitude toward other people.
        There are about eight common causes of dementia of which Alzheimer's is only one. Alzheimer's is particularly characterized by not being perceptible to the sufferer. Other types of dementia may be obvious to those who have them depending on situation. Dementia can be caused by long term exposure to toxins such as mercury or pesticides, Creutzfeltd Jacob disease (mad cow), hypoxia (congestive heart failure, lack of oxygen) , stroke, Parkinson's disease and related conditions and other less common afflictions.
        Transfer of information from short term to long term memory is usually the first and most affected in Alzheimer's. This affects the ability to learn abstract information. It is always invisible to the victim of this disease.
        The so called "aluminum connection" doesn't exist. While there may be a slight increase in the amount of precipitated aluminum found in the brain of Alzheimer's victims it appears to be an effect of the condition, not a cause. Were it a cause we would all have the disease as aluminum is the third most common element on Earth.
        Also, nicotine, caffeine and hot spicy foods seem to have a protective effect.
          Darned ! ! ! I was in the low-risk category until you brought that up ! ! !
            I'll echo what Doozer said: "The best thing you can do is just be a friend and spend time with him when you can."
            Lost my mother to Alzheimer's, it's a tough thing to watch. She lived with us for four years, steadily fading away. It is amazing though, how there can be very brief periods when the person is noticeably more lucid. It never lasted long, but was quite startling when it happened. I came to consider those moments real gifts.
              I don't drink alcohol, smoke, or drink coffee, or tea and I like only mildly spiced foods, no pepper, or garlic.
              Am I doomed?
                Ive been somewhat unfortunate as i have suffered a succession of heart attacks this last few years, i must say that the so called 'genetic' predisposition that runs in families seems to be as simple as having small diameter arteries, what i want to add to the discussion is the fact that after these events memory suffers, it makes me think that there may be a connection between a] strokes b] heart attacks and c] Alzheimer's.
                perhaps the medication is a factor but i remember my mother suffering a mild stroke, she recovered but her memory was not up to what it was.
                Not being medically trained i don't have any real experience to either confirm or refute my findings, personally i have noticed how much i have forgotten since starting back to work last month.
                If the onset of this insidious disease is similar i sympathise with these poor people, it frightens me to think they may be trapped in there...
                a line from a song by the Who, Every sentence in my head, someone else has said, And the End of my life is an open Door,
                puts Euthanasia in a new light don't you think
                mark
                  I forgot so much between stints at my job, that I had to retrain every time I went back to work on-call.
                  I finally got fed up with the co-workers's antics and called it quits.
                  Life is too short.
                    Finis
                    Check this out:
                    http://en.wikipedia.org/wiki/Life_expectancy
                    http://en.wikipedia.org/wiki/Life_table
                    http://upload.wikimedia.org/wikipedi...03_Table_1.png
                    http://en.wikipedia.org/wiki/Healthy_Life_Years
                    Its not so matter of how long you live or have to live so much as the quality of life and well-being and health in those older years.
                    I am 73 and my "actuarial age" is about 83. I am neither counting on lasting 10 years nor am I counting on them all being "well years".
                    There is a very high probability that before I depart this mortal coil (ie "fall of the twig") that my mental and physical capabilities will decay progressively - at an accelerating rate - and I will be progressively less able to do those things that I do in the shop etc. and to "look after" myself.
                    There is a quite high increasing risk or probability that I will get "taken out" by cancer, stroke, or physical or mental decay or failure and that probability increases as I get older.
                    I am well into the "zone" for all of this.
                    Whether or not it will happen is not debatable as it is a certainty.
                    The unknowns are what will happen and when and to what extent it occurs and what impairment it causes.
                    Whether the twig snaps or I just fall off it - the end result is that it is the end game.
                    Sans me
                    Finis
                    http://en.wikipedia.org/wiki/Finis
                      Lost my maternal grandmother to dementia/alzheimers at 93. She was sharp as a tack until she lost her eyesight to macular degeneration.
                      It seemed like she lost her will to live when she lost her sight.
                      I recently had my eyes checked and was told i still have 20/20 eyesight.
                      I'm 53. So far so good.
                      What Evan said about using your brain. I believe that people who spend their days watching mindless TV won't be out much if they get alzheimers.
                      It almost looks to me like they are practicing for it.
                      My signature line says "THINK HARDER".
                      I believe in exercising my brain. I don't think it is much different than exercising muscles.
                      I remember going back to work after a long medical leave for a badly broken femur. It had been over a year and I couldn't remember the combination for the lock on one of my tool boxes that contained the keys for the rest of them.
                      I borrowed an air grinder and a cutoff wheel and was ready to cut the lock off.
                      I closed my eyes and thought as hard as I could. The numbers just popped into my head.
                      Most times I find that if I am stumped on something, I just need to think harder.
                        Well, thank you for that information, Evan. I drink a sh[t load of coffee, eat really spicey food, like in habenaro salsa, and I like everybody. I've never been a patient in the hospital and don't get sick much. So, when I die, it won't be from anything serious.
                        Patrick
                          LOL
                          No TV here. If I had a TV, I would watch it. But if I don't have a TV, I don't miss it at all. Instead, I do stuff in the shop, read books, or worst case -- peruse technical and news sites on the web. I love to learn.
                          I don't mean to brag, but I have continued to learn thoughout my life. I'm always doing projects and acquiring new hobbies that I don't really have time for. I'm always reading non-fiction. I try to keep up with world news. I frequent several technical and science news sites so I have at least a conversational knowledge of the latest technical developments.
                          Most of my fellow HSM members seem to do the same.
                          Compare that to my best childhood friend. He was the school genius. Straight A's, honor roll, 99 percentile on standardized tests. He breezed through the tough math and science classes that gave me fits. I figured he would grow up to be some kind of rocket scientist or college professor.
                          Instead, his brained stopped learning when he finished school. Today, he can't carry on an intelligent conversation about global warming or current events. He buys a new used car every year because he doesn't know how to fix his car when it breaks down. He doesn't know how to download and install computer software. He spends his spare time watching M*A*S*H reruns and playing strategy games. He doesn't read anything (except the Bible).
                          As bborr01 put it, it's like some people are practicing for Alzheimer's.
                            Well, Evan. My mother was none of those hings and still had dementia, not the Altzheimers kind.
                            Eventually she tired of staying around so the left.
                              My hindsight is still 20/20 but everything else is going to hell.
