What do I need to view a SLDPRT file
  • What do I need to view a SLDPRT file
    Title says it all. I dont want to buy solidworks and when I serched google everyone is wanting to "check" my puter. Scares me. I dont need some crap taking over my computer trying to sell me their software..Thanks Jim
    You need Solidworks. Or another 3D modeller that can open .sldprt files.
    And depending what version it was created with, you need that version or newer to read it, as files are not backward compatible.
    Peter
      I thought solid works did a free viewer ?
      http://www.edrawingsviewer.com/pages...ks-Viewer.html
      Don't use SW so can't check.
        You might try the first item at this SolidWorks page. Our fabricators use similar viewers from SolidEdge unless they have a need for the actual package. Den
        http://www.solidworks.com/sw/product...-downloads.htm
          The free viewer only works if the part is saved as an e-drawings file, which would have a .eprt or .easm file extension.
            Is the part something you can share? If you send me the part file I can convert it to a jpg, pdf, or a dimensioned drawing.
              Rookie. I tried to put it in a pm but wouldnt attach.
                Trying to view the sterling engine plans on this link.
                http://www.john-tom.com/html/SteamPlans2.html
                  I tried the solid E drawings. It didnt work. I dont know what I am doing so that is probably the problem..
                    I just remembered seeing a viewer from Oracle last week and wondering why Oracle would be interested in this business. There is a 30 day free trial which could be fully functional or might be crippled ... worst case would be with no printing support
                    It opens part, drawing and assembly files. Alibre will open SolidWorks part and assembly files but not drawings.
                    http://www.oracle.com/technology/pro...ks-viewer.html
                    Incidentally, you've got 31 files involved in that Stirling project.
                    Den
                      31?? Lol... It only has several parts!
                        How's your French ?
                        _Assem1.SLDASM
                        biellle piston.SLDDRW
                        arbre moteur.SLDDRW
                        volant d'inertie.SLDDRW
                        cylindre piston + coulisseau.SLDDRW
                        manivelle déplaceur.SLDDRW
                        plateau supérieur.SLDDRW
                        manivelle piston.SLDDRW
                        cylindre piston + coulisseau.SLDPRT
                        plateau supérieur.SLDPRT
                        PISTON MOTEUR.SLDDRW
                        colonne support.SLDDRW
                        plateau inférieur.SLDDRW
                        biellle piston.SLDPRT
                        déplaceur.SLDPRT
                        manivelle déplaceur2.SLDPRT
                        Support de déplaceur.SLDPRT
                        plateau inférieur.SLDPRT
                        volant d'inertie.SLDPRT
                        colonne support.SLDPRT
                        piston.SLDPRT
                        biellle déplaceur2.SLDPRT
                        manivelle piston.SLDPRT
                        entretoise.SLDPRT
                        tige déplaceur.SLDPRT
                        manivelle déplaceur2.SLDDRW
                        tube déplaceur.SLDPRT
                        rayon.SLDPRT
                        roulement.SLDPRT
                        Rondelle.SLDPRT
                        Ok, 30.
                        Here's a .jpg view from one perspective.
                        Den
                          Down loaded just the e viewer program, not the publisher and it opens the Sterling part and drw files OK here ?
                            That worked John. Thanks once again! Jim
                              I believe Rhino can import a .sldprt file. If you don't have access to Rhino you can download a trial version. Or maybe a Rhino user can convert them to a format that you can use.
                              Michael
