DRO Scales 9x42 Hartford
  • DRO Scales 9x42 Hartford
    I want to put a DRO on my Hartford 9x42 mill, which is basically a Bridgeport copy, does anyone know off hand what size scales to use? I thought I might save a bit of time if I can just do the shopping without having to go and work it out first.
    I am also open to suggestions on brands of DRO.
    Thanks
    Will
    Well, First how far does your mill go in the X direction?
    And how far does it go in the Y direction?
    And how far does it go in the Z direction?
    Thats the size of scales you need. Or rather, the travel, the scales will be a little longer. But Generaly you buy a DRO by the travel, not the mounting size since mounting is usally a custom solution anyway.
      Thanks for the reply Black Moons, i realise all that, I was just trying to save myself a bit of time in the event someone knew what size already.
      Will
