Titanium?
  • Titanium?
    I thought I read somewhere that these pins were Titanium. Is there an easy way to tell if they are or an Aluminum/Titanium alloy?
    Titanium is supposed to be 50-60% heavier than aluminum. Also, try a small test spot with a file. If aluminum it should be much easier to cut.
    "Work hard. Tell everyone everything you know. Close a deal with a handshake. Have fun!"
    -- Harold "Doc" Edgerton
      I can file it but it seems harder than 6061.
        Are you planning keeping these and continuing to use them? If not file off a small pile of chips/dust and put a propane torch to it ... titanium *really* reacts/burns brightly.
          It looks like Ti to me.
            Purplish color? Looks like it to me, as well.
              Cool, I'll try that!
                weigh it (accurately) adn measure its volume by displacement of water in a jug.
                do the maths and the density will tell you.
                Setting fire to it is much cooler tho
                Just south of Sudspumpwater UK
                  I ground some off and got sparks but not a lot. Could it be a Ti/Al alloy? 6061 Al gave me zero sparks.
                  I'm saving the fire thing for now. Jen just got home.
                  I can weigh them accurately but the volume thing will be a challenge.
                    It's quite simple Mike, here's the procedure and it is very accurate provided you have some accurate digital scales that can measure to 1/10g or prefferably 1/100g:
                    Tare a beaker of water (A).
                    Weigh sample completely immersed, but suspended in water (B). Hang from a piece of cotton.
                    Weigh sample resting on bottom of beaker (C).
                    Density = C - A/ B - A in g/cm³
                    Titannium and Titanium alloys are between 4.43 and 4.71g/cm³
                      I have access to a scale that measures milligrams so I can do that.
                      At work tomorrow.
                        It will spark very bright white against a grinding wheel...
                          Did that. The scale wouldn't stay in milligrams over 100g but I pressed on and got 2.77g/cc.
                          I guess it's an Aluminum alloy of some sort.
                            Simple test
                            Aluminumn>? Titaniumn? use a Q Tip dip it in muriatic acid (toilet bowl cleaner works) apply to inside of part just a small amount . Aluminumn will dissolve in muriatic. If it fizzled dump into a bowl of water . There you go.
