PDF to DXF converter?
  • PDF to DXF converter?
    Hi All,
    Sorry if this is a repeat. It seems to me that someone here had pointed to a good freeware converter that would take a PDF and convert into a DXF or DWG for editing in a CAD package. Try as I might, I can't seem to get the search right and find it.
    Anyone?
    Thanks for any insight.
    -Al
    Google pdf2dxf. First hit: http://www.cadkas.com/downengpdf11.php
      I use pstoedit:
      http://www.pstoedit.net/
      Been around for 15 years or so.
        Is doing that worth the effort?
        The few times I've tried that sort of import, there was so much work to clean up the import that I ended up re-drawing the part.
        Maybe I was doing it wrong..... or trying to be too perfect and get a 'real" cad drawing out of it....
          Thanks for the pointers, guys. Not sure why I could not seem to find those, my Google powers must have been waning yesterday. I'll give those a try. I have used one in the past, but that was a computer or two ago and I could not recall what it was called.
          JT - I do get what you are saying, and the few times I have done this before, I pretty much ended up redrawing them as well. But it did sort of get everything in approximate position and proportion, which is mostly what I need in this case. The absolute numbers are not so critical as everything sort of fitting together. The conversion gave me something I could basically "trace" my real drawing onto.
          Thanks again,
          Al
