This is a rewound armature for a 90 volt treadmill motor to make it run on 24 volts. I went up two wire gauge sizes and reduced the number of turns by a third. That should raise the output to at least 2 hp but it cooks the brush holders if run very long at the level so I need to improve the brush holder plate.
This is a 4 speed 3 motor transmission that I built for my electric bike a couple of years ago. It worked but is too complex for good reliability so I took it apart.
