The cut knurling tool in the HSM March/April issue looks interesting, but why is it shown with a form knurl? Am I missing something or is this just using the center of a form knurl to perform axial knurling?
Cut Knurling tool in March/April issue
It looks to me to use the center of the knurl but not completely sure. The pics aren't real clear. What is clear is I want one and the next edition of the magazine can't get here fast enough. JimJIM : You don't get a 2nd chance to make a 1st impression.
The wheel really is cutting rather than just impressing the pattern. If you picture the contact area between the wheel and the workpiece as the workpiece is rotating, because of the tilted axes the contact point is moving sideways through its contact arc so the leading edge is pushing a small chip.
It's a really nice write up and I'm anxious for the next installment too. I already went out to the shop to look for those little bearings I'm sure I have somewhere..
I don't know what diameter it's designed for, but with cut knurls you can cut much larger then you'd expect with regular knurls. Comparing with what I see online I'm sure this one is good for at least 6".
As to the original question: perhaps there's less difference in the knurls than I thought, and a form knurling tool will work as a cut tool if presented in the right way.
hey Russ....I'll own up to this one
I'm not sure what you mean by 'shown with a form knurl'?? there's a pic of a form knurling tool; it's just there for comparison/context. the tool is a cut knurling tool, does a complete fully formed knurl in one pass....i think there's a pic of it doing so in 5/16 stock (demonstrating how little force is involved)
It'll cut almost any size dia, theoretically infinite. The two round arms carrying the spindles are adjustable; they need to be in different positions based on the diameter of the work. They rotate in opposite directions and are geared together, you turn a knob and they move, one clockwise, the other counter...the lever on top locks them in place via a double split cotter (if there is such a thing!)in Toronto Ontario - where are you?
Originally posted by gwilsonIs it necessary for the 2 knurls to be geared together? If they were just independent,wouldn't each knurl make its own cutting track?in Toronto Ontario - where are you?
Originally posted by McgyverI'm not sure what you mean by 'shown with a form knurl'?? there's a pic of a form knurling tool; it's just there for comparison/context. the tool is a cut knurling tool, does a complete fully formed knurl in one pass....i think there's a pic of it doing so in 5/16 stock (demonstrating how little force is involved)
I have a couple of cut knurl tools from Vogel Pieterlen, nicely made from Switzerland but I think the company is defunct. The cut knurls are fairly difficult to find being 25-5-11 form and only one maker I know of any more. The tool being described in HSM is nicer. The Vogel uses a much simpler mount for the tool - there's a bushing through the center of the knurl wheel fron the back and a screw from the front into the tool body. It seems to work pretty well, you can tighten up the screw and push the bushing against the body but the tool remains easy on the bushing. The downside is that it requires a pretty big opening in the knurl.
Originally posted by rkeplerThe "purchased parts" list shows the knurl wheel as "5/8 OD, 1/4 ID 40TPI" (paraphrasing) and I don't know of a source of inch pattern cut knurl wheels.
lynnl, they are regular knurl wheels but the style with out the chamfer....patience, there's more content comingLast edited by Mcgyver; 02-24-2010, 06:09 PM.in Toronto Ontario - where are you?
The way I understood the article he said the knurls are cut by the edge of the wheel, not in the grooves. He said the knurls are CUT not rolled as with the standard knurling tool.
The finished knurl is the same diameter of the work it was cut on because it does not raise the metal.It's only ink and paper
The knurling tool is a masterful piece of work and amazingly complex. But seriously, someone would need need to have to do a hell of a lot of knurling to justify the time and effort expended to build that tool. It is way over the top for me. I'll just stick with my old scissors tool.
RandyDo yourself a favor and see if your TV carrier has America One News Network (AONN). 208 on Uverse. It is good old fashion news, unlike the networks, with no hype, bias or other BS.
A forming wheel will have rounded sides, a cutting one needs sharp edges to be able to cut. You can't use a cutting knurling wheel in a forming action and vice versa.
Nick
