aciera drill
  • aciera drill
    i recently obtained an aciera precision drill press which uses schaublin 6mm collets-does anyone know where these can be found
    ent,
    Schaublin collets (W Series) are usually described as the shank diameter. Such that a W12 collet has a 12.0mm diameter shank, is 44.5mm overall length, with a 16.0mm head diameter. Collet front angle is 15* with a 0.461" x 1.25mm Buttress thread. these are available upto a maximum 8.0mm dia. grip. Other collets in the W series range are W20, W25, and the odd named W31.75!!
    I wonder if the shank diameter of your Aciera drill collet is 6 mm then you may need a Lorch style collet, details are:-
    Shank 6mm dia.
    30.0mm O/length
    10.6mm head dia.
    20* 30' head angle
    5.0mm x 0.7mm P Drawbar thread
    0.5mm to 5.0mm capacity range
    Please confirm your collet size and we can find exactly what you need.
    RR
      it is definitly a schaublin collet because it has the SA logo but it has the dimensions of the lorch collet you descibed
        ent,
        This is a 'Lorch' collet manufactured by Schaublin then. The Einheit number for this collet is 304E. It is currently available new from
        Crawfords Collets
        Tower Hill Works, Witney
        Oxfordshire
        OX8 5DS, England
        Tel +44 1993 703931
        or email: [email protected]
        Their Cat ref. for this collet is #2801 range of sizes are 0.5mm to 5mm (these collets DO NOT collapse down and can only be used for their stated diameter)
        They'll cost about آ£20 ($34USD) each.
        For second hand collets try an advert on the 'Private Ads' of the following website:-
        http://easyweb.easynet.co.uk/~chrish/homepage.htm
        Come back if you have no luck as I might know of some other places to try.
        RR
          <font face="Verdana, Arial" size="2">Originally posted by Ragarsed Raglan:
          ent,
          Shank 6mm dia.
          30.0mm O/length
          10.6mm head dia.
          20* 30' head angle
          RR
          </font>
          collet size is 6mm
            ent,
            Crawfords Collets
            Oxfordshire
            OX8 5DS, England
            Tel +44 1993 703931
            RR
            </font>
            thank you for your help
