Any info on Sheldon 10" lathe
  • Any info on Sheldon 10" lathe
    Does anyone know any of the specs for this lathe, Catalog number L-56, Model TLWQ 10477. The only info is 10x36 quick change gears.
    From a picture I saw it looks clean.
    I was wondering the typical stuff, hs bore, standard/metric threads/ # speeds, auto feed(s), parts?
    Would this be a good lathe for a hobby person?
    thanks,
    Warren
    [This message has been edited by WarrenInDe (edited 10-28-2003).]
    Take a look at this Sheldon Group:
    http://groups.yahoo.com/group/Sheldo...4?viscount=-30
    Cut and paste as necessary to get the whole URL into the address box of your browser.
    Good Luck,
    Jim Larsen
      Unless there is another letter before the L, that lathe is a bench mounted lathe with a rear drive. Weight is probably around 700 lbs.
      The L series swing 10-1/8", 56 is 36" between centers. Headstock is MT#4, 1-1/16" hole through spindle. Spindle nose likely 1-3/4"-8. 60 threads and feeds available.
      The Sheldon is an excellent machine. Comparable in quality to South Bend or even better. It is of heavier construction then the Heavy 10. It is a very good choice for the HSM.
      If it is an XL, it is better yet, 2-1/4"-8 MT #5 spindle on that.
      Jim H.
