Cutting internal keyways
  • Cutting internal keyways
    I want to make up some gears and need to cut 15 or thereabouts 3/16" keyways in a 7/8" bore, the bore being around 1" long. I have a shaper, so could make up the appropriate tool and cut them on it. I also was looking at a lathe mounted (hand powered) reciprecating tool used for engraving graduations and wondering about adapting that. I have no room for a press, so broaching is not a possibility. Anyone have any other methods that are worth sharing?
    Michael
    You have a shaper but no room for a press? An arbor press really does not take up that much space.
    But given what you've got, I vote for using the shaper. After all, that kind of axial cutting is what it's designed to do.
      The shaper followed me home...
      I bought a beautiful fly press once but got it back to the shed and discovered that I had no where to put it, so reluctantly on sold it to a guy at work who was lusting after one.
      I have half a double garage and is already home to a mill, lathe, drill press, shaper, welder, panbrake, table saw, thicknesser, bandsaw, linisher, surface table, optical comparator a few benches and a shelf or two. I can't quite work out how to wedge a press in (yet)
      Michael
        Well the shaper will certainly work well.
        If if you could find an area for it you'll enjoy the speed and nice looking keyways
        using a press and broach.
        My little Palmgren 2 ton press would easily handle a 3/16" keyway in mild steel, brass or aluminum for example. You could probably cut 15 key ways in around 20 minutes with a good broach and press.
        Estimated force needed for 1 pass broaches at bottom pf page-
        http://www.dumont.com/prod6c.html
        But since you have a shaper, may as well put it to work!
          I've cut internal key ways with a hacksaw and file. That wasn't a lot of fun, but it did get the job done. The shaper sounds like your best bet.
            Use the mill quill as a press.
              Make a planing tool for your lathe.
              Mount the Center of the tool on the CL of th espindle..Use the lathe as a shaper-planer. Lock the spindle in position.
              K Lively
                Hey Form_Change,
                I recently (last week) cut an internal 3/16" key-way in a 3/4" bore in aluminum using a boring bar on my lathe. I used a 1/2" boring bar and ground a 3/16 HSS tool mounted in my QCTP and moved it back and forth with the carriage wheel. It took awhile, but turned out fine advancing the tool about 5 thou and making several spring passes (tool bar flex). I will probably use this method again as it was easy to do, however I will build a purpose built ram with a much stiffer tool bar in it. It will mount directly on the carriage in place of the compound for increased rigidity. I have seen several examples of these in the "shop made tools" thread on this forum.
                While this works ok in a pinch, using the shaper looks like a better deal to me. If I was going to do a lot of internal keyways, I would invest in a arbor press and broach set.
                Tim
                  I have half a double garage and is already home to a mill, lathe, drill press, shaper, welder, panbrake, table saw, thicknesser, bandsaw, linisher, surface table, optical comparator a few benches and a shelf or two. I can't quite work out how to wedge a press in yet
                  You're obviously not trying very hard if that's all that is in there
                    deltaenterprizes, you shouldn't use the mill quill for a press. The rack on the quill is not designed to be a press and it will not last long doing that.
                      Press
                      Use a hydraulic press and an arbor press with a set of broatches:
                      https://www.machineryhouse.com.au/Pr...stockCode=M500
                      https://www.machineryhouse.com.au/Keyway-Broach-Sets
                        I needed to do this recently and used my shaper:
                        http://metalworkingathome.com/?p=65
                          Do you merely use the frame of the hydraulic press to support the
                          arbour press? Or do you use the HP's ram to move the AP's rack?
                          I was once considering whether to bid on a nice hydraulic press at
                          a local auction for use primarily for broaching. At the time, I determined
                          that the conventional wisdom is that hydraulic presses do not provide
                          sufficient "feel" and that a consequence of this is broken broaches.
                            I concur with not using the mill spindle. You could broach on the lathe by holding the work in the chuck and pushing the broach with the tailstock.
                              There is a photo of a Slotter by; Terry G. on, Page 45 of the Shop Made Tools Thread. That may also work for you.
