Further on the boat anchor Chinese lathe mill/drill I am going to put in a new pin to connect the drive socket to the lead screw. The original fit was very bad causing eccentricity in the lead screw producing drunken threads. The pin (spring) hole was drilled by someone after a couple of beers, not square to the axis nor through the center with much damage to the holes in the socket. I have repaired the holes with threaded plugs silver soldered in and turned everything true. There is a .007" shim locktited into the socket which gives a nice sliding fit on the end of the lead screw.
The lead screw is LH M20x4 acme and the socket/lead screw drive is 15mm dia. The lathe length is ~20" and swing ~16".
Any ideas what shear pin size would be suitable? Material choices I am considering are brass, aluminum and possibly copper.
Thanks, John.
Thanks, John.
