I declare total victory in the quest for a very simple way to make conventional etched circuit boards using a small CNC hobby mill and a cheap 200 milliwatt laser.
I built a regulated power supply for the laser to run it at maximum power. It greatly increased the output with no apparent ill effects since it is designed for use at 6 volts DC. I also had installed a heat sink to ensure it doesn't overheat.
I have made a video of the operation that shows just how very effective the laser is at burning vinyl. It actually produces a very realistic miniature mushroom cloud when it is switched on the work. I didn't even see it until I reviewed the video. This is a frame from that video. [grin]
The video: 3.5mb
The secret of the process is the masking material. It is black sign vinyl which is easily obtained at any sign shop, probably for free if you ask for some scraps. The board is polished and then masked by rubbing down the adhesive vinyl making sure that there are no trapped air bubbles. If you have a bubble lift the film up and rub it back down making sure to NOT to put your grubby fingers on the board or underside of the film.
The laser cuts fast and to avoid overburning the cutting speed must be at least 10 ipm. This will vary depending on laser power and the thickness of the film. The laser must be very carefully focused to the smallest possible point. To interrupt the laser beam during rapids I built a simple adjustable limit switch on the Z axis that senses when the Z moves up to traverse. This activates a solenoid that operates a flag to block the beam. The flag has a small piece of corundum emery paper as the beam stop and is impervious to the laser beam. It also is very non reflective. The video shows how the beam interrupter works.
Here is another nuclear aftermath picture just after the laser finished the board.
Peeling off the vinyl is an easy job if the burn was deep enough, which it was.
This is the board ready to etch. I can't wait to try it on something more complex. I know it will work very well and look forward to making some boards the very easy way.
The video: 3.5mb
