How do you mount and center D1-3 collet chucks?
  • How do you mount and center D1-3 collet chucks?
    I've just received a new D1-3 5C collet chuck.
    It is a no-brand Chinese chuck.
    What is the procedure to mount and center it?
    Thanks
    You just poke the three pins into the three holes on the spindle nose and tighten the three cams. I just pull them all in a bit in turn then go round again tightening them.
    Monarch 10EE 1942
      What Peter said.
      But check the taper and see if it's off, then chuck something straight and make sure things are axial. If not you might pull the backplate off the chuck (looks like it a separate piece), mark the pins 1-2-3 for the spindle nose and take a cleanup pass when mounted on the spindle. Things should come in axial at that point. If there are still issues you might find that the taper has to be ground in place.
        Another possibility if the chuck is not concentric and you are feeling lucky is to remove the backplate and index the chuck around to find a more concentric set of holes.
        I've never had this problem as I make up collet chucks on the lathe. It's not hard and at least gets the things concentric.
        Michael
          Just try it first.
            Might seem a darft question, but you do have a D1-3 spindle?? Seems a strange request.Especially on a self centreing ( Centering) mount.
            Regards Ian.
            You might not like what I say,but that doesn't mean I'm wrong.
              Not a daft question at all. After all if the chuck is off, it would be obvious to any one.
              More "daft" questions:
              Is the chuck off?
              If not a D1-3 spindle nose, why did you buy it?
                I bought one of these identical for £100 delivered .I have nothing but praise for it ,it works Great. Then I bought on of his lordships designs for a 5c collet chuck which fits into this and accepts er 32 collets I bought that but have not yet tried it, as I have faith in the good man enough to buy and sleep soundly on his well founded good name.You should be delighted with this have fun and good luck Ps it should fit just like any other of your chucks.I suppose you've fitted one of them before have you? Grandpa Alistair
                  Is the chuck off?
                  Come on guys, I am a newbee not a dummy.
                  The reason I asked is that I already have mounted it and it is not concentric. I have not tried remounting on different pins.
                  I took the back plate/collet chuck off to inspect it.
                  The back plate was probably dropped on the edge and had a little bump. I carefully filed it off. Then I put a piece of 600 sandpaper on a granite plate and very lightly sanded(just a dozen of figure 8 movements) the back plate to make sure nothing protrudes.
                  I am going to remount it and see if this bump was causing the problem.
                    BTW What makes the D1-3 mount self centering?
                    The pins and the holes that pins go into are not precisely machined or ground. There is some degree of play.
                    How come there is no provision for fine adjustment on D-1-3 mount?
                      It relies on the short taper.
                        Alex;
                        I bought a bison collet chuck and carefully turned the adaptor plate and still had a small amount of runout. .003 or .004 if I remember correctly.
                        One problem is these chucks can have is the mounting surface can bes slightly out of square with the cylindrical axis. I have a friend that setup a 1" dia pin perpendicular on his surface grinder. Put a 1" collet in the collet chuck and mounted the collet chuck to the pin. Ground the back side of the chuck. He said his chuck was perfect after that.
                        I had a different approach. I turned down the mounting hub on the adaptor plate to .004" undersized so the collet chuck would be adjustable. Next I drilled and tapped some 10-32 holes and use button head screws to adjust the collet chuck for runout. This worked out well for me.
                        Outback
                        So much to learn, so little time
                          It's self centering because the short taper on the machine's spindle nose is supposed to lightly interfere with the female taper on the chuck, while the flat faces around the pins pull into tight contact (no gap anywhere). Assuming the spindle nose is decent, and you've got no chips caught in the gaps, the chuck should center every time. Mine do.
                            Just the way you tighten the mounting screws on the backplate will affect the truness of the chuck quite a bit. I bought one for a D8 nose lathe at work,and by tweaking ALREADY tightened mounting screws,got it to run to .0001"
