Four Jaw Chuck
  • Four Jaw Chuck
    I have a problem with my four jaw chuck. The chuck is an 8" Taiwanese Grizzly.When I indicate a 1 1/8" shaft to zero at the face of chuck and move out 6" the shaft will be out +.020 and -.020. I have tried different shafts and the same problem. I numbered the jaw positions and it is always #1 and #2 that shows the problem. If I trade the two the problem is reversed. Any ideas would be appreciated
    It sounds like the jaws are not square, (If I'm reading correctly).
    Chucking on a big ring, and boring the jaws might solve the problem.
      Not sure if this is the answer but I had a similar problem awhile ago. You need to use a shaft that you are sure is round & straight like a dowel pin. Try the same setup w/ another shaft.
      ed
        If you determine that the chuck is the problem not the shaft, try moving all the jaws around while noting the various readings. You may come up with a combination that works significantly better, if so make a note of the combo that works and keep it somewhere safe.
          I agree. Before recutting your jaws run a indicator across the clamping area. If they are not sq. your indicator will show it. It will only take a few thousandth to cause a .020 runout on a six inch shaft.
          You should get the same indicator reading from the front of the jaw to the back.
          Donnie
          Visit my site for machinist videos free charts & more
          Machinist Classifieds Free Listing
            Had a batch sent to me by a Northern tool dealer in the UK with the same fault.
            The slots for the jaws were milled at an angle.
            I gripped one on a bar turned true in the lathe and faced the register off. this made the chuck run true bur the outside wasn't.
            By the time I had it all skimmed true I had spent more time than the chuck was worth.
            I was told to scrap all 10.
            I made a rotating 4 jaw on a MT4 taper for the small TOS with the trued up one for myself.
            One went on the welding positioner as it was, run out isn't a problem on that and the rest were given away to friends.
              "One went on the welding positioner as it was, run out isn't a problem on that and the rest were given away to friends."
              So mine is in the mail?
              please visit my webpage:
              http://motorworks88.webs.com/
