View Post
USA Maryland 21030
Finally got my old Bainbridge 7x12 bandsaw cutting with no derailments, help, etc! So stoked. Just cut a section of 3/4" rebar like butter!!
Love bring tools back to life.On the hunt for ALL things Wade 8a Lathe. If you have ANY leads for parts, tooling, etc. Please send me a private message.
Originally posted by Darren M View PostFinally got my old Bainbridge 7x12 bandsaw cutting with no derailments, help, etc! So stoked. Just cut a section of 3/4" rebar like butter!!
had to cut a lot of rebar for a basement wall replacement we were doing for the pastor... I do not know how many I cut, but I was using a portaband, and eventually I realized that the teeth had long worn off, and the thing was basically rubbing it's way through. We did not have another band, either, of course.
The rebar was pretty clean, but a little rusty. may have been the rust, may have just been "rebar" made of whatever junk they had left.CNC machines only go through the motions.
I tried to cut some HF rebar with a bolt cutter, and barely dented it. So I used a hand hacksaw to saw about halfway through, then used a BMF hammer to break it. Only had a couple cuts to make, and I touched up the burrs with the grinder.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
Originally posted by J Tiers View PostRebar is the devil.
Originally posted by thaiguzzi View PostI'd look after my saw blades, be they band or hack. The best way to cut rebar is with an abrasive disc.( I think I'm kidding....)
Originally posted by thaiguzzi View PostI'd look after my saw blades, be they band or hack. The best way to cut rebar is with an abrasive disc.CNC machines only go through the motions.
I have a surface grinder, have had it for more than 10 years , could never understand why the rapid downfeed didnt work. Obtained a circuit diagram a few years ago , it was a hand drawn schematic from the 1960's it is complex and difficult to follow as there are many interlocks and the diagram is not in english its Czech. I finally bit the bullet and head down I read the schematic out loud untill I understood how this works, my wife said nothing which was probably best. There is nothing wrong with the machine , everyone should know you should energise the mag table and press both down feed buttons at the same time to get the vert down feed operational . i filled the coolant with 20 gallons of water and some coolant stuff then had a plesant afternoon grindingMy neighbours diary says I have boundary issues
Originally posted by Yow Ling View PostI have a surface grinder, have had it for more than 10 years , could never understand why the rapid downfeed didnt work. Obtained a circuit diagram a few years ago , it was a hand drawn schematic from the 1960's it is complex and difficult to follow as there are many interlocks and the diagram is not in english its Czech. I finally bit the bullet and head down I read the schematic out loud untill I understood how this works, my wife said nothing which was probably best. There is nothing wrong with the machine , everyone should know you should energise the mag table and press both down feed buttons at the same time to get the vert down feed operational . i filled the coolant with 20 gallons of water and some coolant stuff then had a plesant afternoon grinding
Got a chuckle out of this, almost like getting a new machine with extra features. Glad you got it sorted out.
Reading a complicated Czech schematic is one thing but I'm always amazed when someone has had a piece of equipment in the yard for several years and has never once read the owners manual. Then when someone else points out some of the machines' features that are clearly discussed in the manual, it is as an almost biblical revelation. Definitely a Kodak moment. LOLHome, down in the valley behind the Red Angus
