Made a wire catch for my hole saw box. When I bought the set years ago, the box had no provision to keep it closed. Don't know if it was missing, or never had one. It's been a PITA but since the set doesn't get a lot of use, fixing it hasn't been a priority. A few days ago I pulled it off the shelf, the box came open, and dumped the contents on the floor. Luckily, most landed on the rubber fatigue mat and no damage was done. I made the catch from some wire left over from hanging a suspended ceiling grid. That's some tough stuff, not easily bent to tight radii. I started out by making a sort of prototype from thin copper wire, then used that as a pattern to make the finished piece. Not much of a project, but something to add to this thread.
Missing catch:
Box contents:
Copper pattern and steel wire for finished part:
Tough to bend:
Last edited by Dave C; 11-28-2018, 07:54 PM.“I know lots of people who are educated far beyond their intelligence”
Lewis Grizzard
Still fixing the table.... got the one leg of it fixed, and found that all three others were either cracked and sagging, or were sagging and pulling away from their pegged joints. Even the screws were pulling out. It's SUCH a crappy design. So now I have 3x more work to glue them back together and re-install with longer/more screws.
One of them is pulling away, but seems to be still glued, as it will not come out, even though the bottom (that has screws but no pegs or glue) has pulled 1/2 inch away from the surface it should be flush against.... I hate this table, it is leaving soon..4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
Originally posted by J Tiers View PostStill fixing the table.... got the one leg of it fixed, and found that all three others were either cracked and sagging, or were sagging and pulling away from their pegged joints. Even the screws were pulling out. It's SUCH a crappy design. So now I have 3x more work to glue them back together and re-install with longer/more screws.
One of them is pulling away, but seems to be still glued, as it will not come out, even though the bottom (that has screws but no pegs or glue) has pulled 1/2 inch away from the surface it should be flush against.... I hate this table, it is leaving soon...
How do you make threadlock set immediately? Easy, simply realise the disastrous mistake you've made and require to disassemble the two parts!
Use lower strength threadlock you say, it's dismantleable with hand tools? Yes, but not when both parts are round and smooth....which of course, these were.
Did get some brackets made to hang one of these new-fangled kitchen grids and got to have a quick play with some Delrin for my next job. Seems to face nicely at least.
Originally posted by Cenedd View PostHow do you make threadlock set immediately? Easy, simply realise the disastrous mistake you've made and require to disassemble the two parts!
Cheers. Useful to bear in mind for future swearing sessions. In this case though, the other end was held vaguely captive in leather (my wife's boot) so taking a blowtorch to it may have resulted in grievous injury!
Ended up taking pliers to it and then scotchbriteing the toolmarks back off it on the lathe.
Originally posted by Cenedd View PostCheers. Useful to bear in mind for future swearing sessions. In this case though, the other end was held vaguely captive in leather (my wife's boot) so taking a blowtorch to it may have resulted in grievous injury!
Interesting. Not seen those before. Managed to find them on Amazon once I'd worked out what to search for. One to add to my basket when I'm doing the retail-therapy thinghttps://www.amazon.co.uk/dp/B00004SBBE
Originally posted by TGTool View PostTerminate a table - with prejudice?4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
