Just epoxy all the stuff into the bins. Won't fall out then ;-p
You just gave me a good idea. I've been wondering about trying to catalog everything and an easy way to locate which bin something is in, and if I even have what I'm looking for without going through and looking in all of the bins.
If I take one item out of each bin and epoxy each item onto a piece of cardboard or hardboard in a grid that matches the bin grid and display them as panels, I'll be able to just see all hardware nicely labeled and displayed and can quickly see if I have what I'm looking for and know which bin to go grab it from too, vs looking through all of the bins. It would also be a good way of organizing the bins in sections.
Most bins have a card holder in the front to write a description.
I can also see inside the bins. Walking around checking 100's of bins and bending up and down to see if you have something is what I'm trying to avoid.
It'd be cheaper to just glue a picture of it to the card board. That's how they do it at the hardware stores.
I was thinking of just taking pictures but think it might be hard to gauge the actual size from the pictures. I have so much unknown and non-labeled hardware that it would take forever to actually size it and label it so I was thinking a visual display that is significantly condensed is probably the easiest way. And when I'm looking for an unknown sized nut for example, if I glue one sample of each nut I have to a hard board, I could actually try threading the bolt that I have in my hand into the nuts until I find one that fits/etc.
I guess you can't tell bolt size by looking at the threads, use a caliper if the EYEcrometer does not work..
I arrange mine in drawers with partitions then label.
So 1/4 inch , next drawer 5/16, next 3/8..... I may have 3/8 to 2.5 and another drawer for 3/8 longer than that.
Same with nuts. . And the dividers separate fine from coarse most of the time. Lockwashers from flatwashers etc..
You could turn the picture into a line drawing and put that on there to identify the fastener type/style. I don't have any of mine labeled. I keep a pretty good selection of 1/4, 5/16 and 3/8" bolts and screws from #6 to #12 and 1/4". I can usually tell the size and thread by looking at them. I don't need no stinking labels. When I go, I sure don't want to make it easy for the auctioneer. He's going to sell them as a lot anyway. Let the next slob worry about it.
You definitely have a lot better calibrated eyeball than I have!
I wouldn't need labels for those but I would at least keep like items in an area of arms reach or so. But that's the way I work. I don't always need a washer, nut and bolt but some people do. I usually don't need small screws getting in the way of looking for nuts either. But, arrange the bins for you!
They definitely need to be re-arranged. I mostly just threw them up there as I was emptying bags of hardware that were previously just stacked on shelves.
Nah, I work with those sizes all the time. I can tell an #8-32 from a #10-24 on sight. Same for the others. A lot of my taps are loose in a draw. I can pick those out too.
Added: That metric stuff in another story though.
Reason: Addition
Same here, M3 to M24 I can eyeball correctly about 99.9% of time. M2.5 might need caliper to differentiate from M2 and M3.
Metric fine threads are also usually quite obvious but those I have to measure if they are "extra fine" or just fine.
You can tell also solid carbide drills or endmills from HSS drills/mills without even thinking about it, solid carbide feels way too heavy in your hand.
