Originally posted by PStechPaul
View Post
Get a bin, with a lid, something shoe-box sized or so. Then go buy a box of manilla envelopes that fit nicely, vertically, in said bins. Office supply stores sells all kinds of sizes for these envelopes. Put each type of part in an envelope and write what it is on the outside. R value, type, etc... As much or as little information as you want. Then, put them in the bin alphabetically. Get a new type, another envelope to stuff in where it belongs. Just a pen, no label maker required. No endless sorting of drawers. No putting 2 types in one drawer because you've run out. If you have too many of one type to fit in a single envelope... so what, use 2, or more. Easy to leaf through and find what you want, and you can pack the bin pretty much full before moving to a second one. When you move on to that second one it's easy to re-sort... say pulling out all the high wattage or whatever to the new bin. Oh, and when you knock the bin over... worst case, you have to re-alphabetise the bin. Dump a drawer cabinet over... ug!
No database required, unless you want.
Resistors, caps, diodes, LEDs, transistors, whatever... each gets an envelope and goes in the relevant bin. It works well. The only issue, and it's minor, is that the glue on the envelope flap can sometimes seal and have to be peeled open again. Might even need a new envelope... might waste $0.20.
I don't know that it would work particularly well for stuff you need to see rather than read. I very rarely measure how long a screw has to be... it just has to be "that" eyeball long. Much easier to just open a lid and scan, especially if the part it's going through is in your hand.
David...
