It is sorta bathroom-esk, agreed!
Originally posted by plastikosmd View PostIt is sorta bathroom-esk, agreed!Location: The Black Forest in Germany
Originally posted by RB211 View PostWalked around the beach in front of the hotel in Guam...
RB211, Having lived on Guam for two years and appreciating how small the island is, I'm wracking my brain trying to place those scenes. When I was out there (early 80's) almost all the hotels were on Tumon Bay. Maybe that's where you are; that would make the near promontory "Two Lovers Point," but that distant promontory doesn't jive with my memory. ...Unless you were standing at the extreme left side of the bay, a vantage point I was never at....?Lynn (Huntsville, AL)
Repaired a cheap dial indicator that was broken (dial was loose, went every which way). I decided I should take it apart and see how one of these things worked. Put it back together and now it seems to be working. I wasn't intending to repair it, mostly just see how it worked since I thought if I took it apart, it was never coming back together I thought, but it was simpler than I thought in design. I suppose I didn't need to take it apart that far either, just putting the needle back on firmy should have been enough.
Started putting it back together
The dial re-zeros accurately every time so I think it's good. Doesn't feel like a quality indicator though, my 2nd hand german indicator is lightyears beyond this.
Previously dug the floor lower in this garage to install an 8' x 16' garage door. Finally, hung the man door. That first step was getting a little tiring.I installed a wider door so I had to saw the block wall wider. For the new standard pre-hung door, I had to pull the brick mold and make extension jambs because of the thickness of the block wall. Joined the extension jambs with biscuits.
I probably should lower the light switch too lol.
Now you need to design and build an automated robotic inventory storage and retrieval system:
Automated storage and retrieval allows for a higher storage density, freeing up otherwise wasted floorspace. Call us to know more.
By Thomas Philippi - TGW Mechanics GmbH, Wels, Austria, [1], CC BY-SA 3.0, https://commons.wikimedia.org/w/index.php?curid=5132691
As a leading company in conveyor technology, Stöcklin offers logistics solutions and storage systems for small parts warehouses in industrial companies.
The Emergence of Automated Storage and Retrieval Systems Automated storage and retrieval systems (or AS/RS) have quickly become a huge part of tons of industries. While an
USA Maryland 21030
I'm still recovering from the flu, so I have not done much.
But this morning I found the lid of the extra fancy Keurig coffee maker would not close. Google showed a few different ways to get it to close, most of which were based on the principle of "try this to see if it works". The Number one cure for the problem was to stick your finger in a hole as you put pressure on the lid each time you closed it. Number two was to squeeze a part of the hinge each time you closed it. Number 3 was to pull down on a certain part.
That seems rather unscientific to me. I don't like unscientific "fixes".
I played with it for a while and found that FIX #3 worked for me. Then I studied it to see what parts shifted when I pulled down on that part. I found a metal shaft with ends trapped in slots cast in a plastic which shifted upward and allowed the hinge to pivot. Closer examination showed the shaft had wallowed a depression in the plastic on both ends. As I reverse engineered the plastic supports I realized that there should have been some sort of pad under the steel shaft. There was even a slit for a slice of something to fit into.
Obviously I needed to make a "rubbing pad" to protect the supports. I found a 6" by 1/2 inch wide strip of light gauge metal in the garage. It was just the right size when cut into 3/16 x 1/2 inch strips. I happen to have some sheet metal sheers that chew out a 3/16 inch strip as it cuts. I added small strips of 3M super two sided tape and fit them in.
Works like a charm.
Once again, I've shot myself in the foot. The replacement model that I would have bought had more bells and whistles. It does lattes and stuff. But this one will probably work for another few years.
DanAt the end of the project, there is a profound difference between spare parts and left over parts.
Originally posted by danlb View PostI'm still recovering from the flu, so I have not done much.
Works like a charm.
Dan
