  • this weekend I:
    - adjusted the garage door spring with the wife's help. It was sagging due to a mix of age and the added weight of insulation on it. Sits flat against the jams now and makes noticeably less noise going up.
    - hung a hammock chair from the ceiling in the room of one of my daughters
    - made hardwood jaw faces for my wood working vise
    - made little "tables" for my mini bender, roller and bench grinder (with drill sharpener!) so I could mount them in my wood working vise
    - turned my old work bench into 2 sets of shelves, one for shoes and one for useful stuff
    - moved the camping stuff out of the shed and into the garage, moved some crap out of the garage and into the shed
    next on the list before I can move onto a knife making project is changing the oil in the car and swapping a battery in an iPhone 6.
    oh, also watched some episodes of Ozark on Netflix, really neat series with Jason Bateman.
    • Yup we quite enjoyed Ozark and we are looking forward to the next season!
      Jon
        ...next on the list before I can move onto a knife making project is changing the oil in the car and swapping a battery in an iPhone 6.
        Sounds like a busy weekend. I'm glad it's not just me being lumbered with all the trades then. I have some capacitors to replace to try and get something of my son's working again but my favourite is still my mum..."You know about plumbing, don't you!" (no question mark...it too pointed to be an actual question...more like an accusation). "No mum, I work in IT *sigh*". Doesn't stop me being dragged into electrics though....and the moment I ever dare to do any of my own plumbing, I'll be fresh out of excuses!
        • Time to go buy a load leveler...
          • I had a stent removed from my left ureter.
            Yes, I do have ALL the fun.
            Len
            • Rb211 use two slings, adjust as needed .
              2 motorcycle tiedowns may work..
                yup, that was all the stuff I'd been putting off while building my workbench Thankfully the word hasn't gotten out that I'm fairly handy and all my family is >6000 miles away, so most of my non-family time is my own..
                • I’m working on an 12” Craftsman vertical bandsaw conversion. Step one is building a stand. I gathered up some material I had lying around here is the video on the progress https://youtu.be/1ravt4JdlcA
                  • The video is OK, and the project may be worthwhile, but 15 minutes just to cut and weld a few pieces of bed rail and steel tube is a bit too much. Some of my earlier shop videos are also too long, but now I know that a complete (simple) project can and should be condensed into about 10-15 minutes, or less if possible.
                    Also, the 4x6 bandsaw can be used in the vertical position, perhaps by adding a table plate and cutting fence. The differences between wood cutting and metal cutting saws seem to be mostly blade width and type, guide bearings, and blade speed. It may be interesting to see what the end result is supposed to be. The drawing at the end of the video doesn't show very much. But thanks for sharing your shop adventures
                    Other discussion:
                    I looked at an older smallish Walker Turner vertical band saw today. Nice piece of cast-iron that has been nicely rebuilt. I wondered whether this saw would be suitable for light metalwork use, mainly on smaller aluminum parts, perhaps with a maximum of cutting aluminum bar for mill vise jaws...
                    What is the difference? I have the chance to pick up a big (18″), old metal cutting band saw, really, really cheap. (Less than a new 14″ woodcutting band saw). […]
                    Hey Folks, I have a working 12 inch craftsman band saw and a 14 inch harbor freight band saw that is not in working order right now. All I would have to do is mount it to a stand and put a motor on it. The 12" takes an 80"(I think) blade and the 14" takes a 93 1/4" blade. I am thinking about...
                    USA Maryland 21030
                    • PS Paul, my saw doesn’t rotate into vertical position. So I’m stuck with what I’m working with
                      Sent from my iPad using Tapatalk
                      • Originally posted by RB211 View Post
                        In that instance, remove the chuck from the headstock and, if necessary, strap it to the tailstock. I've got a 10lb magnetic V block that makes a brilliant trim weight to level big stuff when moving it with the crane. Move it to the right place to balance the load, a quarter turn of the knob and it's locked in place.
                        • Working on Snow Bike had to cut some Finns off heat exchanger in Overarm Die Grinder,it works pretty slick.It will mounted on tunnel in front of track drivers.
                          • Did the lathe work making a couple of replacement steam cylinder purge valves for the local railroad museum, they ran their narrow-gauge loco off the tracks and smashed one; manufacturer long gone, so no parts available. I have to mill 0.187 x 0.750 slots in the casings and the valve cores next, for the operating lever to run in.
                              See my post here.
                              • Arcane, pretty slick, the lathe manual actually shows something like that
