  • I'm trying to decide what I want for breakfast... I'm thinking french toast, but those damn corn dogs are calling my name again....
    • Originally posted by 3 Phase Lightbulb View Post
      meat twinkie's...
      • Started taking the head of my mill apart to investigate why it rattled AFTER it came to a stop. Had visions of a ball from a bearing rattling about... although the wheels, so to speak, didn't seem to be falling off. Turned out that the drive pulley is retained on the motor shaft with a metal disc screwed into the shaft. That screw had come mostly undone and the disc was spinning around the screw after the motor had stopped. Dab of thread lock should sorted.
        Got my essence of hinge through the post today. "Straight shank essence of hinge" to be specific. You may know them as 2MT reamers....but the customs declaration obviously doesn't lie! Dismantled my tailstock and beat the drill chuck out of it. Gave it a bit of a clean up with the reamer but I'm not sure it did a lot. Cleaned up the thread which was rough as and the shaft which was badly machined out of condensed barbed wire. Could do with a bit more work when I have time. Found the bore of the tailstock isn't exactly round either and they tend to bind up when you are trying to eject the drill chuck. Also found a slot of rust starting on the female taper which is bound not to have helped. I've had my shop for a few years now and never had anything start to rust. Not sure why it's suddenly started being an issue but I've turned up the heating a bit.
        • Started to make something useful out of the scrap piles of end mills/bits etc. (well at least I repurposed one endmill!)
          I was finally able to get some quality coal (500lb) and figured I’d try my hand at making a knife. Now I have an excuse to get 2x72” belt sander!
          I left a bit thick, I didn’t want to burn it.
          Next to start profiling/grinding
          • heck, just use it as it is! How big was the endmill?
            • That's some nice metal work there plastikosmd. Forging a large HSS endmill to that shape takes some skill. Did you use power hammer and other automated tools to forge it, or did you do it by hand?
              Dan
              • Beginners luck, just a hammer
                I have a lot to learn
                I think it was 7/8”
                • I finally pruned my crepe myrtle tree. I should have done it during the cold snap last month but I was sick for most of the month, then when I started feeling better we had daily rain. I'm a Californian so I don't work outside when it's cold or wet, much less both.
                  Dan
                  • Originally posted by plastikosmd View Post
                    Wow. Now I'm more impressed.
                    Dan
                      You're not alone........ I just discovered www.porkys.com is down, and Mike Hunt is not found on PM either...
                      Score is probably now 1 in 52 for AK.
                      That's because you misspelled the site.
                      On the hunt for ALL things Wade 8a Lathe. If you have ANY leads for parts, tooling, etc. Please send me a private message.
                      • Went down to the shop..... did some work and then started walking through and finding all the thing which have no home, or should nt be where they are. Started finding them places and moving them to where they should be, 3 hours later I am still not done, but I stopped.
                        3313 5160 4357 4344 3174 9120
                        Birds are NOT real, they are spying on you
                        • Heck yeah! If you can do that with just a hammer and end mill, you deserve a 2x72 sander.
                          I made another carbide insert holder for my Suburbanized fly cutter. It's 5" and holds a APMT/APKT insert.
                          Assembled my new Wen 4x6 metal band saw and gave it a test drive with the included 14tpi blade then a 8/12tpi blade. Also attached a mister/coolant nozzle and plumbed that in.
                          Left the phone in the house so pictures may show up tomorrow.
                          • As this was a relatively new experience I am surprised about how bright the coals/fire is. Do people wear sunglasses when they do this? It is hard to judge the color but I kept feeling like I was staring at the sun too much
                            Maybe next time just use more coal and create a cave like structure, I think I had too much fire on top
                            plastikosmd
                            • I went down to my temporary shop , one day left, then I got to start to move my crap out..
                              Shoveled a bit of snow.
                              Tried picking up heavy end of my 9 inch South Bend.. ugh. .
                              Lucky the loading ramp was excavated and is now ready for use. 8 or 10 inch rise to the pickup tailgate.. nice
                              Had a beer. .
                              Kid came by to work on his bike and one of my old bike shop customers..
                              Had a beer..
                              Helped the kid with his CB 750.. had to whip up a drift to drive out steering races.. made a drift on south bend,cleaned up his axle. More beer and Fireball.. mmmm.. drove Another race out of another frame. .no joy..
                              Another visitor. . Got stuck on kids bike.. have to dig out a useable lower race tommorow.. go to my frame stash..
                              All in all pretty good day, bit of bike work, bit of visiting, a bit of machining, a few bevvys..
                              Damn.. gonna miss that place.. it was my shop from 96 ish to 2015..
                                Simple project, screw cl, gonna keep it!
                                I have this combo vac/sandblaster. Typical snapon-
                                Pricy. I think I paid a few $ years ago. Works well. Put it up on cl for the same $ and about 20 emails
                                Of no-show “buyers” and and some offers for 100 or less (new they are 2200)= I will just keep it!
                                Anyway, nozzle was starting to wear. The gun is easy to rebuild, just washers and o-rings when needed. Time for a tighter nozzle to improve speed
                                Much faster now, great for flat panel work. No dropcloth needed and can use in the garage without mess
                                Thats what I was looking for. That attitude. And yes, many folks have been in that stage also. Good for you. JR
                                Mmm? Maybe less Caffeine. I don't know. JR
                                JRouche
