That's gotta be the wrong blade or something. Pushing that saw around the shop like that is dangerous. If it's not cutting, don't push it. My Craftsman will cut a piece of aluminum that size in about 10 seconds or less. It's a hungry son of a gun. I use it for wood and aluminum. My new Wen chinesium metal band saw would cut that 3/16 piece in less than a minute. I cut a piece of 1/2 x 2" flat in about 3 minutes. Cut a piece off a 1 x 1" in about the same amount of time. I'm running a bi-metal 8/12 blade at 120fpm with mister coolant. I might try a 6/10 blade if I can find one. Or just run the 8/12 faster.
It’s a 10/12 blade, also the saw is set for a speed for steel, also I’m kind of learning how hard to push the saw and where to place it. As I’ve said all along this saw is to fill a need without breaking the bank and be able to move about the shop. Plus the saw is a bit under powered. The motor is off a washing machine. It came with the saw
They look lovely....but you lost everyone when paired the with Brussel sprouts!
I'm not crazy about vegetables, but I don't mind (and often enjoy) broccoli, green beans, or brussel sprouts when they are served in a butter sauce... Especially on the side with a nice aged rib eye
It looks like it works as well or better than my $50 Atlas H/V bandsaw. For sure the table is bigger, which is the worst thing about the H/V, the table is too small, and the saw too low when set up vertical. But it is on a portable stand with wheels, they are just not on the floor when the saw is set up, you have to tilt the stand to roll it around.
None of the smaller bandsaws cut very fast. You need a big DoAll to get a reasonable speed in anything fairly thick.
You have not had good ones.... They are nearly always bad tasting, with what I would call a bitter "iron" taste. But I have had very good Brussels sprouts, I just do not know what was different about them as far as how they were cooked, etc.
What did your Mother tell you about eating your vegetables?
Brussels sprouts, when cooked as usually done, are dangerously close to "punishment food".
When my mother was ticked at my father and I, she might serve something we hated, like over cooked sliced zucchini in butter. It's not bad stuff if stir fried, but I cannot take it in butter, especially overcooked to nearly a mush. There were other similar "punishment foods", but that one sticks out in my mind.
Every day I make something, even if it is only a woodworking chisel handle. Today I made a chip guard for the metal lathe. Drilled and tapped for 6-32 screws.
Everyday I eat a low Carbohydrate diet.
Every day I go for a 45 minute hike in the woods.
Twice a week I help take care of the grandkids.
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. -Ernest Hemingway
The man who makes no mistakes does not usually make anything.-- Edward John Phelps
I have always liked Brussels sprouts - as a kid I called them little cabbages - and also broccoli, which I called "little trees". I like most veggies, except turnips. And I'm not particularly fond of raw tomatoes or cucumbers.
Yeah, no greasy, black, broken fingernails.
Obviously not his hands....
Aye, it's hard to get them all dirty and cut up when you live two seperate and completely different lives each month. The 747 yoke is so smooth, no metal chips or grease in the cockpit anywhere.
