Was that just a standard parting/grooving tool you used for the trepanning? I know there are specific face grooving tools available but between being specific for a limited diameter of groove and costing a small fortune each, it's put me off buying something for when I inevitably need one.
Originally posted by Cenedd View PostWas that just a standard parting/grooving tool you used for the trepanning? I know there are specific face grooving tools available but between being specific for a limited diameter of groove and costing a small fortune each, it's put me off buying something for when I inevitably need one.
Modified parting tool and set of "pressure plates" and large "washers" with centerbores have been very useful, makes quick job of turning large disks.
I should still make couple of larger "pressure plates" with centerbore, the job shown was quite noisy as there is quite a bit of unclamped 316 disk free to "sing".
Still not any deal breaker, did the trepanning at normal carbide speeds.
And I think I should add some sort of boss to the sacrificial plywood disks so it would fit snugly in the chuck bore, staying there securely and centered.
Maybe a thick washer turned to size and mounted with couple of wood screws.Location: Helsinki, Finland, Europe
Edutainment! Teaching my son some electrical (fan installation) and plumbing (faucet swap). And.... getting some help on the five friggin fans my wife wanted swapped. :-0
It's amazing how far this puts him ahead of the average shmo. Never mind the soldering, cabinet making, and Tollexing skills from building a vacuum tube amp together ;-)
Sent from my SAMSUNG-SM-G891A using Tapatalk
Cleaned up after the plant sale. Sold almost everything. Dom't have the numbers yet, but UCIB should do average to above as far as proceeds.
Only problem is that neither my wife nor I want to look at a plant for the next month, but we need to do work around the gardens on the property.CNC machines only go through the motions.
Did my first shingle repair the other day, one involved lying on my gut about 25ft over the ground to reach a ripped up section on the steep side of the house. Saved a few hundred I suspect, not bad for 2 hours work.
Working on a dust chute for the SG today, got the chute portion about half finished. Put the 2.5" vac hose hole on the wrong side so I've got some patching to do.
Sent from my SM-G930W8 using Tapatalk
Anyone else think season 8 of GOT is kind of boring compared to seasons 1-7? The big long awaited battle last night was quite boring and monotonous. Maybe it is budget related but the quality of the special effects, lighting, and cinematic arrangements were quite disappointing.
Originally posted by vpt View PostMade some ramps.
Great idea Andy!
Nicely executed as well. I can see that concept taking off, it really opens up a lot of opportunities and makes loading and unloading much less of a hassle.Home, down in the valley behind the Red Angus
Had the supreme pleasure of moving stuff around in the shop to allow replacement of a water heater. One of those jobs I will hire out happily.
The old heater, which lasted 22 years, started leaking last Tuesday or Wednesday, and "blew" on Friday, after I had already called and arranged for its replacement the day after I found the leak. I was surprised at it "blowing" as it did, it shook the entire plumbing system and house, "started" some faucets, and of course opened a big leak of water, along with some sand, across the basement floor. Had to hustle down and shut it off, cut the water to it, and put down a temporary dam to guide the water to the least troublesome floor drain.
Several decades ago, we had a water heater with a monel tank. Tank would have lasted a century, except that the city had the bright idea of requiring backflow preventers on the incoming water line, but NOT requiring expansion tanks.... so the absolutely rustproof tank was gradually forced out by heat expansion of the water, until it was ripped apart. A lot of that went on, and the city eventually reversed the requirement.
This one was a plain steel tank, probably glass-lined. Replacement tomorrow, unless some other crazy city requirement gets in the way.CNC machines only go through the motions.
On Sunday I helped an old (born May 1931) friend with his telephone (part of a FIOS bundle), and I also tried to program his second remote to work with his Philips flat screen TV. I found several procedures on-line, but none of them worked. I connected both TVs to the main set-top box so he could watch his premium channels (Playboy and HD) on both, and I removed his second STB and took it to the Verizon store so he could stop paying like $9/mo rental, and they gave me a new remote to see if it will work for on/off and sound on his second TV.
This is the user guide: https://www.verizon.com/home/accesso...5_brochure.pdf
Another guide: https://www.verizon.com/cs/groups/pu...ios-remote.pdf
I also tried to teach him how to use a cheap ($20) used Win7 laptop I gave him, but it is quirky and he has vision problems as well as Parkinsons, so I don't think he'll be able to use it.
He also has an iPad that a friend bought for him, but he has had trouble using it, and I was not familiar enough with it to show him. So I took it home with me, along with a book "My iPad for Seniors", and I soon was able to use it. Mostly I just browsed the pictures that were taken with it, used Safari to browse the internet (what's with the stupid compass icon), and I installed a free calculator as well as an 8-ball pool app and a Brainium solitaire app, which I played until the wee hours last night.
One more thing... I have been using Dogpile for a search engine, but lately I have been getting the following web page, which is apparently a "honeypot" used to block hacking attempts by attracting them to it (like a sting) and then blocking them. I thought it might be malware but it appears to be legit, and probably installed by Dogpile.
USA Maryland 21030
