  • Andy
    • Originally posted by The Metal Butcher View Post
      It's 100% concrete. Fully loaded they're 3000+ lbs, they would sink like a rock offroad.
      One of the reasons I don't want too big of casters is that they lean in more on the swivel. I want the stability.
      I was thinking 2 wheels fixed, 2 wheels castering. Keeps the stability, still steers.
      I also generally put the casters on brackets outside the frame. Still within a reasonable dimension, but even castered "in", the floor contact is pretty much under the frame.
      • Cutoff,drilled and counter sunk 300 3/8" holes in75 pieces of 2-1/2x 2-1/2x 1/4" angle.Made up an aluminum fixture to locate and transfer punch all the hole locations.Had one of the guys do the punching while I did the drilling.
        I got two drills setup inline with a bridgeport,those two along with a roller stand made easy work of it.Did the 3/8 thru hole in the Leland Gifford and the countersink in the Summit.
        The Summit drill has power feed which is really handy for things like the countersink.Cycle time for each angle was about 4 minutes start to finish including punching and handling,so not bad.The Bridgeport in this case is being used as a work support
        • Second half of the same job,I pressed 6 graphite lubed bronze bushings into the engineered sprockets along with some hydraulic wiper seals to help keep dirt and grit out long as possible.Also cut four 2" diameter cold rolled shafts.
          • Originally posted by J Tiers View Post
            Great minds think alike! Since the wood is 22" and the frame is 18", I figured on the next one, I'd cut the end runs of angle 4" longer and hang the casters on the outside. Then it would have much better stability. 2 Fixed, 2 steer is what I'm running. The fixed wheels do add to the stability, but not as much as one might think since the frame can flex and enormous amount. I could try to remedy it, but I don't think it's worth trying to fight. It may overload 2 of the casters if it was too stiff anyway.
            snip
            snip
            Whoa. That Leland is a neat old press. What an enormous table! That's a lot of drilling, but it sounds like you got it down pretty efficiently.
            • flipped my table saw upside down. lubed the blade tilting and blade elevation mechanisms. lined up the pulley on the arbor
              flipped my table saw face down. aligned the horizontal motor axis with the arbor
              flipped my table saw upright. aligned the vertical motor axis with the arbor
              I'm a big boy, and I have always been the lift and carry guy. flipping the table saw would have been trivial at 30 or 40. at 64, it's a struggle.
              trying to keep expenses down, because it makes no sense to put money into a saw that was given to me. all the things I need; miter guide,fence, handwheel for the tilt mechanism, can be found for chump change. but the shipping makes it cheaper to buy new.
              • So what did I do?
                I'll let you guess. Anyone recognize the apparatus or what is going on here?:
                • I put lipstick on a pig today. Repurposed my aluminum tool rests I machined for the Baldor that went poof to this Cummings bench grinder
                    So what did I do?
                    Making some kind of "elixir" , no doubt.
                    • Originally posted by jdedmon91 View Post
                      ... I put lipstick on a pig today. Repurposed my aluminum tool rests I machined for the Baldor that went poof to this Cummings bench grinder
                      how does the base work on that? I have several big brake discs, but did not think they were heavy enough or big enough for a grinder. of course the Cummins is probably pretty lightweight......
                      • Originally posted by CCWKen View Post
                        Well it involves super expensive & highly purified water with defined isotope composition as a steam, ice and liquid... and next monday the "value" will be slightly different along with many other "values" worldwide.
                          So what did I do?
                          It looks like you are growing some kind of crystalline structure. Making rock candy?
                          • Originally posted by RichR View Post
                            Crystalline.. sort of.
                            Pic of water triple point cell prepared for temperature calibrations. White "crystal" in middle is co2 flakes used to freeze the central well in the "cell"
                            Accurate to 0.0002 degrees Cel.
                            And water with defined isotope composition is used as the isotope composition has effect on the triple point value.
                            Next monday the SI measurement system is going to be redefined, most notably the mass (kilogram).
                            • All loaded up for my fishing trip. Were leaving at 9:00pm.
                              Mines on the back
                              What 18lbs of roast look like when made into jerky. from l-r, Original, teryaki, spicy buffalo wing sauce.
                              Made some spoons last weekend with the kids, and we painted them with some nail polish. Might be a fish or 2 dumb enough to bite one, we'll see. I told the kids I'll try them all.
                              5 days in the bush with no cell service. Can't wait.
                                Mines on the back
                                Holly Molly! Those are some funky looking fishing boats.
                                Here is our fishing yacht in "fighting lady yellow" Awlgrip
