  • I decided to get a fever, pretty crappy time to be home alone with two kids. But I couldn't stay awake all evening, fell asleep and woke up later with two cats on me. Kids had spilled milk on the kitchen table while I slept.
    • I also have a couple of those benches that need new wood, but no clue as to what type to get. Cyprus is avalable here, but spendy and most likely bendy as well. Teak would be great, but heaven only knows what that would cost. Suggestions anyone?
      Lewis Grizzard
      • I spent the day cutting out parts for a toe jack of my own design. Actually, it's a combination of ideas stolen from you tube videos with a couple of my own thrown in for good measure and to fit my needs. I'll take some pics today in case someone else is nuts enough to want to make one. Most of the materials have been lying around the place for years, but had to bite the bullet and hit the local steel supplier for the 1/2" plate for the base. I asked if they had any drops about 8 x 10 and he said sure. How about 20 bucks? I just gave him my best f... you look, and he said give me ten. I was tempted to get really stupid, but needed the plate so said OK. I actually started this project a few weeks ago, but that base plate was holding me up. There is a scrap yard not too far away that sells steel for $.14 a lb., but you have to buy the whole piece. The smallest they had was about 8x10 ft. so it was bend over at the steel supplier.
        Lewis Grizzard
        • Originally posted by Dave C View Post
          The first pic, I had to add both the V-shaped support and the cross bar, replacing a couple of worthless 20 ga braces. Solid as heck now. with a 1/8" thick strip front to back in he middle to tie the slats together and to the support.
          Rhw second and third are of the other one, for that I put a piece of angle across under a middle slat. and also have a strip in middle to tie slats together. VERY solid support, although I may replace the angle pieces, which are heavier material, but not super effective. The angle is on top of the lugs the slats bolt to, so it is supported well.
          It was interesting cutting and shaping the plastic lumber for that serpentine top piece. But the plastic stuff will not rot as wood does.
          4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
          "There's no pleasing these serpents"......Lewis Carroll
          • Great idea JT. I saw some of those deck boards at a surplus store the other day. Going to have another look at them as I didn't check the price while there.
            Lewis Grizzard
            • What I used was actually called "trim", and it is not as stiff as the decking.
              But the decking was not available as narrow. I was too lazy to cut it lengthwise, and did not think it would look very good unless I really worked on the cut edges. Might have been wrong.
              On the "wine theme" bench, the slats were 3" nominal, or 2.5" actual width. the other one, (of which I have two) has slats 50mm wide actual, which is not a standard size of US board, and is highly inconvenient..
              • Last night I cut up the fiberglass cap that had been on my Toyota pickup last year when a tree fell on it:
                After a few minutes with an old carbide blade on my circular saw:
                I'll be taking the sides and glass to the dump, but for now I'll keep the top part. It's about 4' x 6' heavy fiberglass and might be useful for something, maybe even a roof for a small shed. The edges are only about 1/4" thick but most of the middle seems to be maybe 1/2" or 3/4" thick. It's pretty heavy. Any ideas for other uses?
                USA Maryland 21030
                • I had this little generator a while. I took it in to a local small engine shop to get it running. They explained they could not get the parts I needed. So I took matters into my own hands.
                  https://youtu.be/UNx-3oXJZPA
                  • Decided to put together the up-to-now unused garden bench, which means I had to sandblast the cast iron parts. Way to big for a blast cabinet, so had to put up tarps outside.
                    Sheesh, I had forgotten how the fine white blasting medium flies around... Full face shield , but it was a sweaty task, and quite a bit of it stuck to me, down my neck, etc. next time I will have to remember to put a cloth over my head, I have some more stuff to clean up pretty soon. Blasting cabinets spoil a person.
                    Was the first time of using a new-to-me portable old Craftsman blasting setup, and I was impressed at how well it worked. Economical with air also, my little portable (also Craftsman) compressor kept up well, which I was not expecting it to. The blasting setup cost me a whopping 10 bucks, including about 40 lb of the fine white grit.... I think it has already paid for itself.
                    • Messy job for sure. I use an old crash helmet with a clear face shield covered with the cloth full head shield that came with the HF blast rig. Also added a fitting in the helmet for a low pressure air line for cooling and keeping the dust out. Works pretty well.
                      Lewis Grizzard
                      • I've never broken a tap (now why would I go and tempt fate like that?!) but today I twisted one - it doesn't count as broken if it's still in one piece, right? Maybe it's just metamorphosed into a spiral flute!
                        M2.5 was an interesting experience. Tapping chart sad 2.05mm drill. 2mm did not cut it, neither did 2.1mm. 2.2mm just about worked but it was threatening to twist the tap - set of three, by the way. I figured they were taper, plug and bottom but given that they all seem to have the same amount of taper on them, I'm gonna call them Try, Try and Try-again! 2.3mm made it a doddle....but we'll see how strong the thread is yet.
                        Can you tell what it is yet?!
                          Carbide insert holder.
                          A 2.3mm drill is close to 55% thread engagement, should be okay. What is the material, any lube?
                          I've never been lucky enough to twist a tap, they usually just snap.
                          I realize it's softer but sometimes it's nice to have some "forgiveness" built into a tap.
                            Well thats something new with taps!
                            I have been using cheapo M2.5 taps from ebay and they have worked surprisingly well. Always power tap on hand-held setup, M2.5 is small enough that you can hold part in one hand and cordless drill in another.
                            Key stock blank? That's what I use, pretty easy to drill and tap. For best result you want to harden it so that it doesn't mangle so easily if insert breaks.
                            • Originally posted by Willy View Post
                              Yep. Double ended TCMT so I can chamfer the end of threads with one end and, clearance allowing, inside of bores with the other.
                              Had fun failing to calculate the centre of a triangle twice. Luckily I checked it visually and didn't wreck the part.
                              It's an eBay-special length of 10mm square bar in either EN1 or EN3 - the latter if memory serves. CT90 cutting oil for lube but it seems that the thread charts were vastly optimistic on the thread engagement the tap would stand up to. Power tapped (with a hand tap) the first few turns just to get it straight and then hand-tapped the rest after changing the mangled tap.
                              Yeah, I was surprised...but in a good way once I realised it was going to just back out fine.
                              Given a machine tap and now knowing it needs 2.3mm starter hole, I think it'd power tap fine. Have two spares and don't anticipate doing too many of these so I'm going to refrain from buying all of the taps!
                              I've been looking at blow torches for a while (not the cheap throw-away type) with a view to trying some hardening and tempering. Not sure EN3 is particularly good for hardening though and I'm not sure what it'd do to dimensions etc.
                              • I had a 3/8" x 10 tpi ACME tap twist. But, to be fair, it was home made from carbon steel, had no relief at all, and I obviously hadn't hardened it properly (my first home-hardening job). I ground off the twisted bit and used it a second time.
