  • Shop reorganization continued with a new tool wall and the moving of tool holders to new places.
    • Dennis, your shop is smaller than mine, gives me hope that I can organize mine to be functional.
      Sent from my SM-G950U1 using Tapatalk
      • Wait, that looks like a WOOD shop! I’ve heard about that stuff. No stock sizes, comes in crooked pieces of ramdom length you have to straighten before you use it. Lots of internal defects they call knots, strength in one direction but not the other. Changes size with the weather, rots, needs expensive finishes etc. So what is that stuff good for?
        • To be fair, it's not that different from metal:
          Originally posted by garyhlucas View Post
          No stock sizes
          plenty of stock sizes....but never the one you want/need.
          Turns up bent because the postman was having a bad day.
          of random length you have to straighten before you use it.
          of random length because someone cut once and measured not at all.
          Occasional internal defects where they just chucked stuff in the foundry.
          Changes size as you machine it. ...and again when it cools down (after you measured it, obviously).
          rots,
          Rusts.
          Needs faffing about with paint, heat or a forlorn hope that cold-blue is going to actually behave itself this time round.
          Well, quite....but it keeps us out of trouble!
          • I've been spending the last few days on the shop reorganization, but today I worked on the electrics for the FP2. I decided to add another 3-phase outlet to the electrical box. That way I won't need to run a cable for the lathe and can plug both mill and lathe to the same spot.
            The additional outlet is not hooked up to the switch but is always live if the electrical box is hooked up.
            Almost everything is hooked up. One really weird thing is the yellow cable that goes to a regular 230V outlet on the front, I tested the terminals it's hooked up to and it's hooked up phase to phase (!), so anyone plugging anything in there expecting 230V will get 400V single phase. I have no idea what the previous owners used this for, but good thing I didn't plug in anything.
            Regarding the color scheme on the cables, it's not the modern standard and I decided to reuse old cables and hook them up using the same color scheme to keep everything the same.
            I also removed this transformer to make room for the 3ph outlet. I am not sure if it's original or what purpose it served. It's a 230 - 100V transformer but only 100W. Not sure what need I'd have for that.
            I also re-routed some of the wall outlets, fortunately an easy task since the cables are all just held to the walls with cable clamps and not hidden. I decided I really don't want to have a cable across the floor so I routed the outlet to the ceiling instead, as close as I got it, then I will drop down a power cable to the electrical box.
            • Plugged in, and tested out the new toy at work. In another life many years ago I programmed a 5axis mill, but I've never used a rotary 4th axis before. It's been a long time since a program of mine had an "A" in it.
              https://i.imgur.com/FHB9fxIl.mp4
              Should be interesting setting up this production job..... I normally HATE production, and we don't do a lot of it, but I'm actually excited to tool this up and get it running. Then hand it off for someone else to run . I've been looking into a few new jobs the last couple months as a way to learn new things and challenge myself a little more. This came along at the right time.
              • Strong storms yesterday knocked out power for about 3 hours, and another quick wet storm this afternoon. More tree limbs came down:
                This one got hung up in a tree:
                Rain makes a small pond:
                Tibbs is ready to go back to the house:
                USA Maryland 21030
                  Strong storms yesterday ... Rain makes a small pond:
                  Small pond??? I don't think that even qualifies as a puddle.
                    Machine lighting perhaps?
                    No storms but had a brief power cut here too. Obviously they waited until I was up in the loft, surrounded by boxes and dripping with sweat before they plunged me into darkness.
                    • First test run of the Deckel with all major parts mounted.
                      Forum software says only one video so the 2nd one is linked, just doing a test of the noise levels really...
                      https://www.youtube.com/watch?v=GbGAkgyTOBY
                      • Project continues unabated, rest of the day I spent prepping parts that still need to be painted. For these parts with lots of difficult to reach places I decided to get serious and I used a hot lye bath, dangerous stuff but oh so effective. It was so effective I cleaned a bunch off small parts too. Makes the ultrasonic cleaner look like a chump. Also used a pressure washer and compressor to blow dry. Then WD-40 on a rag on the more sensitive areas.
                        I am beat now, tomorrow I will mask the parts to be painted....
                        • 787 #1, in Nagoya, Japan.
                          • Previously milled down the support block for the gas strut in my mill so it would clear the new z-axis scale. Re-blued the newly cut surface and reinstalled it. Found it didn't quite clear the plug on the wire so I needed to mill a 2 X 2mm step into it. Did that and the re-blued it again. This morning I refitted it....and found I'd cut the step in the wrong face. A mistake I maintain that any idiot could have made...and did! So re-cut it and re-blued it a third time this morning.... clearly I needed the practice!
                            • Retension a torsion garage door spring for one of the 20’ doors and got ready to load the parts OC3 onto new owner’s trailer
                              • Painted the work table (and more) and reassembled it, now all I need is a vise, and some end mills and other tooling.
                                Also the horizontal mill support got refinished, here I am trying it out for the first time
                                Next step is to begin reassembling the DRO I think, and hook up the 12V so I can have some lights on the on off buttons.
                                Would be nice to paint he doors too this week though.... Last week of vacation now and when that is gone my productivity is gone too. Back to a day a week of shop time more or less then.
