What I did today- making some lighting for a local pub. Aluminum channel with led strips, etc. I needed to attach mounting brackets, but avoid having anything sticking up where the led strip would go, so I opted to use flush setting rivets. I had some on hand so I tested the hole size and the recess so the head would come out flush. I epoxied the brackets into place, then drilled two holes in each. Before I even started drilling, one of the channels slipped and fell to the floor. All the brackets came off. For some reason I was able to drill the holes and apply the right chamfer on both sides without knocking the brackets loose, but the first time I pounded one rivet into place, the other brackets came off. Took me two hours to do what should have been a half hour job. After I drill and tap the brackets so they can be held in place I'll stick the led strips down and solder the lead wires in place. Then I'll pour an epoxy layer over it for protection. That should be interesting- there won't be enough depth of epoxy to self-level, especially over the 50 inch length of one piece, and 28 inch length for the others. I'll just have to try to pour to the right depth as I slowly go from one end to the other.
I'm a little tired today, after the dance fest rock and roll food bank fundraiser last night, so I'll likely leave the epoxy for tomorrow.
