I'd always thought it was to reduce the chatter you can get with any form tool as more of it is engaged. I can't say I've had any trouble just plunging on an SC4 but I'm not exactly making gauge-perfect threads for inspection.
Originally posted by DennisCA View PostMaybe that is it. I am using a cheapo chinese threading insert. Maybe I should try grinding my own HSS.
Too high cutting edge has same or worse effect than dull edge so double check that and rather set 0.1mm too low than 0.1mm too high.
I had also problems of "sudden deeper cuts" before I installed the DRO to my lathe. Old and sloppy lathe is not super consistent how much the crosslide moves and heavy vibration for example is quaranteed to move it around.Location: Helsinki, Finland, Europe
Originally posted by DennisCA View PostBeen working on a simple carbide grinder actually, but not ready yet, and now I wonder after seeing Stefan Gotteswinters latest videos if a slow speed one is better, or if I should have both. This one runs at 2800rpm.
Are the low RPM ones any good for situations where you need to do more material removal, such as re-profiling a carbide blade for scraping? Like going to a smaller radius.
I do like the idea of going slower and using lubrication to prevent dust.
Originally posted by MattiJ View PostI had also problems of "sudden deeper cuts" before I installed the DRO to my lathe. Old and sloppy lathe is not super consistent how much the crosslide moves and heavy vibration for example is quaranteed to move it around.
screw the threading (geddit?!), what about the cats? Those must be special Scandinavian cats to like the snow. Love the picture of the 2 jumping at each other, I'll have to show that to my kids.
Don't know if you do this when threading, but I take spring passes every few DOC changes and especially before checking for fit/ measure. I find that helps alot on my smaller lathe. Also don't forget to get the cross slide back to zero by dialing it past and then back to zero in the same direction to take backlash out of the equation. I'd assume that you do that as a matter of course, but doesn't hurt to mention just in case.
As for me, all I did yesterday was add a bigger battery to my rear helmet light. It's a $2 cheapy and the battery wasn't lasting 2 rides, so dug around in my bag of salvaged li-ion batteries and wired up one that wasn't too big. Plus lots of zipties.
edit: daughters loved the catsLast edited by mattthemuppet; 12-03-2019, 06:30 PM.
I would like a DRO on my lathe as well. Though it seems it's the compound that's the real problem on mine. And the nut on the cross slide is worn and needs to be replaced, probably same story on the compound but I have not been able to figure out how to disassemble the compound.CNC machines only go through the motions.
Probably what happens, I need to make some new lead screw nuts for this lathe. The screws seem to be fine but the nuts are worn. Just another reason to get the Deckel running again... Hopefully I am soon there...
I also found another Deckel FP2 for 700 euros or so, + shipping a few hundred more I guess, but it has no tables and no vertical head and no accessories. And I think it lacks the Y-axis lead screw, it is disassembled from the rest of the machine.
I am pondering if I should buy it as a spare parts machine, I'd keep the horizontal spindle and the gears and shaft as spare. Disassemble it and sell the components online as spares, they seem to fetch money. Real issue is lack of space, and putting out lots of money on a non working machine,
Originally posted by mattthemuppet View Postscrew the threading (geddit?!), what about the cats? Those must be special Scandinavian cats to like the snow. Love the picture of the 2 jumping at each other, I'll have to show that to my kids.
There was also a video:
The well known South Bend and Boxford instruction book 'Know your Lathe' recommends putting the tool a little above centre (obviously diameter dependent). They don't give the reason but it means there is a component of force outwards to push the cross slide out to take up the slack. The relative inward and outward forces depend on tool geometry.
Honed the trepanning tool in my Akurate hole cutter - looks like this but somewhat cleaned up! Stuck some 16 gauge steel on the mill and cut me a lug-less back for the dial indicator in my carriage stop. Much sharper edge on the tool but it still doesn't seem that keen on cutting steel. Relief in all the right places too.
Got the brush holder mounted on the side of my mill finally. The what now? Long story. I've been trying to mount a digital scale on the side of the mill but have it encased so it doesn't die the first time the fly cutter comes out to play. Because it's been so well planned and not at all evolved as I gothe rectangular tube had to have a slot cut out the front to attach the head. That's now covered by a brush-style draught excluder. Just have to clean all the chips out and get the scale back in there and see if it plays!
Went with the rather unorthodox - but effective - method of clamping the aluminium F channel to the rectangular tube, drilling a 3.6mm hole and then roll-tapping both parts M4. I figure that since they were tapped in-place the threads must be in-sync and so things like them jacking apart or being out of sync shouldn't be a problem. Unlike some of my previous attempts, these are perfectly in line.
