Went to Radio Shack and bought some RCA plugs to extend my speakers in my shop. No..... I didn't miss type "Radio Shack". (There's one in Belle Fourche S.D.)
Spent some time last night trying to work out a good rope knurl. Trying out a Millgrain wheel, it's a bit smaller than I would like and it's taking me a bit of time to figure out the best process, but I think I can make it work and looking at the construction of the Millgrain wheel might be able to upsize it to make a larger knurl.
Cayuga, Ontario, Canada
- 1 like
- 1 like
Been working on the Benchmaster again. Getting closer to being done, or at least ready to re-assemble.
The knee is 3/4 done, the table slideways are not done yet. In the pics, I am scraping the top of the table. When that is flat, I will get the flat ways on the bottom of the table parallel with the topside. Then the dovetails will be scraped to parallel the table slots and hopefully the sides also. If the sides do not line up, they will get scraped parallel to slots and perpendicular to the top surface.
Then the table will be fitted on the knee, and checked for alignment. The results of that will guide the scraping of the table way dovetails on the knee piece to get the table lined up properly vs the column and the ram axis. I have the H-spindle for this also, and I want that to line up as well,
4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
- 6 likes
Originally posted by Tom S View PostSpent some time last night trying to work out a good rope knurl. Trying out a Millgrain wheel, it's a bit smaller than I would like and it's taking me a bit of time to figure out the best process, but I think I can make it work and looking at the construction of the Millgrain wheel might be able to upsize it to make a larger knurl.
Home Machine Shop Tool Making - Machining A Set Of Vintage Style Rope KnurlsMachining A Set Of Vintage Style Rope Knurls, by Clickspring In this video I make a set of classic rope knurling wheels, to put some ornamental rope knurl pa...
Popped open the top of my PM 12X36 Taiwan lathe and noticed a lot of metal chips that were there from the factory, which is par for the course on these imports. I sucked out the oil which looked dirty, and replaced it with Mobil DTE Heavy/Medium which is an ISO 68 oil, and ran it. Also tore down one of my wooden tables, have away a portable AC unit, and cleared some much needed floor space. I will make chips for the first time on the 12x36, and I may even change out the spindle oil on the 10EE and try making some chips with it as well!
And will get the CNC going again.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Made a shift knob for the plow jeep. I use a winch to raise and lower the plow and I got tired of holding the winch switch while shifting so I just combined the two. The previous abuser of this this heep brazed on (poorly) an extension shift shaft for some reason, and that broke off a couple years ago, so I've just been shifting with a stump anyway. I'm going to cut off whats there, and weld on a 1/2" bolt for this to thread onto.
Tried printing threads again. No good, but should be fine if I run a tap down it. 1/4" hole is for the switch wire to go in. There's a cavity in the head and a hole from the back I can insert the switches from.
- 3 likes
JFLingg @ 25 miles east of Colorado Springs, Colorado
- 3 likes
