This weekend I finally reassembled and closed up the gear box.
Both shafts back together. I had to disassemble the lower shaft again which I had put in first. It was completely impossible to get the three front gears in with the lower shaft assembled. So the upper shaft goes first, but try and get as many of the components for the lower shaft in place as well before hand, not a lot of space to work with...
Finally able to start putting components back in place:
Chain drive for the feed gearbox, still need to put in the drive shaft for the Y-axis before putting back the drive belts and pulley.
And the gear box selector is back. This was a difficult operation, trying to fiddle the thing just so, so that it would go into the locating pins (and it's not that light) while not disturbing all the forks on the backside that need to mesh against the gears and selection mechanism. Never mind that the gasket didn't want to stay in place. I had to resort to vaseline to keep it stuck against the gear selector. I probably tried 40 times or so before I got it.... A rubber mallet was required to get the thing to seat properly on the pins. And I had to put the selector in the speed that put the all the selector forks closest to the middle, which I found was 400 rpm.
Tested changing the speeds and rotating the spindle by hand and all the selector forks seem to have engaged properly.
Drive shaft for the Y-axis goes back back on.
And the aluminum cover, this protects the pulley belts from getting dirty from the chain drive.
Drive pulley goes on next
Then I pretty much just had to put back the side covers and the controls.
So pretty much back together again now, I refilled the gear box with oil and tested all the speeds and they seem to work. When the vertical head is engage the noise is loud at over 500 rpm, the straight gears meshing in the long reach head really make a lot of noise. I assume this is normal for the long reach head machines. The machine is quiet even at 2000 rpm with only the horizontal arbor.
Also I can tell the epoxy paint I used is getting discoloration, blotches that are lighter. Kinda annoying to see... I think epoxy paint might be a good primer, but perhaps this is what happens if you try and use it as a finish paint too, might have been better with polyurethane paint for a finish. But I am not going to bother with that now. Just an FYI.
- 4 likes
Hah.... I'm out of town, and then while I am supposed to do other things, a good client asked for drawings on a rush modification project..... Done except for final checks and slamming it into the outbox, but quite the hassle to do when away from the office.
I'd rather be scraping a 2 x 3 surface plate to 40 points...... and I almost mean that.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
Just drove 620 miles to get home today. I need some of that whiskey y'all been taking about. I did pick up a case of Spotted Cow on the way, but that's for a friend. If I wasn't lazy and it wasn't late, I'd go down and check the supplies of beer etc, but I'll probably hit the hay.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
I checked the local weather on the internet. It's -37oC and the windchill is -51oC.
For those of you who are Celsius challenged, that's -34.6oF and windchill is -59.8oF.
I'm staying in the house today.Location: Saskatoon, Saskatchewan, Canada
Up where I was, in Mnnesota, it was a balmy 15F or so.
The usual January temps are up to a max of 0F as a high for the day.
Warmer this morning -47c ,large semi trucks on main highway 1/2 a mile away sound like a locomotive a 100 ft from the house at this Temp.
You know it's cold when walking across drive way snow crunches like walking on egg shells.Last edited by Tundra Twin Track; 01-15-2020, 01:16 PM.
