Replaced the front rotors on a friend's ram 2500 van that were warped. First side took a couple of hours due to the pita pad retaining pins that stop tha caliper from sliding off. Had to use a Wilson bullet vise to push the pistons back into the caliper (didn't have a c clamp big enough) before the caliper would come off. All done now and no more vibration under braking. Plus I got 2 big bags of Lindt chocolates and a set of large 1/2" drive Allen sockets for my troubles. Saved her $500 which was pretty neat.
Finished this dial indicator stand for my mill. It was a microphone stand that was in the dumpster. I cleaned it up and made the quick lever nuts for adjustment as the others were missing. Uses a 3/8" T nut and all- thread to the table. I'm looking forward to using it this weekend for a project.
Anyway, I enjoyed making this project this evening after work. had to share!
TX
Mr fixit for the family
Chris
After thinking about it last night, this is not very useful to indicate in any thing as all the movement is with the table and the indicator is fixed to the table.
OH well it was a exercise in machining,. Might have to figure out how it might actually be usable some where else in the shop.
- 2 likes
Originally posted by Dan Dubeau View PostWould make a great vice stop if you made a small cross rod to go where the indicator does. Worked with a guy years ago who had one similar, and always wanted to copy it.“I know lots of people who are educated far beyond their intelligence”
Lewis Grizzard
- 1 like
Dan D, Dave C,
Do you guys mean something that would be perpendicular to the vise as a stop or parallel more in or above the jaws? I can see the smaller shaft that has the indicator mount as a direct stop in the parallel position, is this what your suggesting? Good idea, I'll have to try it.
TX
Chris
Originally posted by mattthemuppet View PostReplaced the front rotors on a friend's ram 2500 van that were warped. First side took a couple of hours due to the pita pad retaining pins that stop tha caliper from sliding off. Had to use a Wilson bullet vise to push the pistons back into the caliper (didn't have a c clamp big enough) before the caliper would come off. All done now and no more vibration under braking. Plus I got 2 big bags of Lindt chocolates and a set of large 1/2" drive Allen sockets for my troubles. Saved her $500 which was pretty neat.
thanks, didn't think of that, but yes sticking a pry bar through the caliper and levering it to the outside would have done the job. To be honest, most of the time was spent going "why the .... won't this damn caliper come off". Once I saw a couple of pins sticking out of the back of the non-piston pad the penny dropped and it was pretty quick after that. I guess they're to prevent the pads from falling out or something. Weird that the replacement pads didn't have the pins, though we ended up reusing the OE pads as they had so much life left in them.
Definitely bigger parts than the cars I've worked on
Just a word of caution on the levering brake calipers back: some vehicles require a special tool to screw the piston back in rather than just pushing it. I found this out when massively overthinking things ("How unusual" I hear you say!”) only to find that mine doesn't need it......and then that I had plenty of pad left, you just couldn't see it.
TX
Chris
Originally posted by Mr Fixit View PostFinished this dial indicator stand for my mill. It was a microphone stand that was in the dumpster. I cleaned it up and made the quick lever nuts for adjustment as the others were missing. Uses a 3/8" T nut and all- thread to the table. I'm looking forward to using it this weekend for a project.
TX
Chris
OH well it was a exercise in machining,. Might have to figure out how it might actually be usable some where else in the shop.Helder Ferreira
Setubal, Portugal
USA Maryland 21030
