Paul, it's time to let that fridge go.
Originally posted by Tim The Grim View Post...What do normal folks do when they buy stuff like this ?
When you consider how much it cost you, and how many people made a profit along the way, it's a miracle that it can even exist.
- 1 like
Originally posted by Tim The Grim View PostWhat do normal folks do when they buy stuff like this ?
Got the pump in, all plumbed but shaft seal leaking like a sieve. Lift does function though.
Pump out and starting the rebuild.
Also scrapyard gloat today. 10pc 18”x42” 1/4 plate, 2 40” pieces of 3/16 channel and 2 10”x40” 1/8 plate
600# or so, 250$
Not a steal but online prices are well over 1500$ plus ship
Fridge cleaned up pretty well. Sprayed with detergent, blasted with hose, sprayed with bleach, hose spray again. Leaving it outside to dry and continue airing out. While working on my shed, I saw that the fridge had fallen off the steps - but then I saw thatMr Tibbs apparently thought something smelled yummy and he had torn up one of the bags of food. He seems to have survived, but I won't welcome his doggy kisses for a while!🤮
The shed...
USA Maryland 21030
I was asking my professor a question at his office today, and when leaving I commented on his fresh McMaster 126 that just showed up. He said "Want it? Take it, I do it all online now." So now I have a brand new McMaster 126. I should have asked about the grainger catalog thereas well since their site is much worse, but I didn't want to be greedy.
I'm visiting a relative. She was worried about getting locked out of the house. I suggested a "hide a key" box of some sort. She was luke warm to the idea because she has gardeners poking around outside every week. I suggested a two step approach. First was a key to the storm door embedded in the railing around the deck. The second was a key to the front door hidden in the storm door. Secrecy is the key here.
I lucked out. The door has hinges that are screwed to the jam, resulting in a 3/8 inch gap between the jam and the door. The hinge is not really noticed since they made the edge of the door like c C channel. My other bit of luck is that there are two flush steel screws an inch below the bottom hinge. A magnet would be ideal to hold the key in place.
I did not want to make it too thick so I drilled a 15/64" hole in the bow of the key and pressed a 6mm rare earth magnet into it. A very light coat of epoxy made it permanent. I used a magic marker to darken it so that it would disappear into the shadows. The hinge side of the door is located such that there is never direct light on it.
She was pleased with the result. I stressed the fact that it's only secure if she NEVER tells anyone where it is.
- 1 like
The drug blight has reached this small rural area. Every once in a while someone wanders through the neighborhood looking for unlocked cars and houses. Old single ladies tend to be more cautious than old men.
Yeah, I disclosed the secret, but not the address so unless you live close to here and have excellent computer skills excellent geocaching skills and want to face a scared old lady with a loaded 32, she's probably safe.At the end of the project, there is a profound difference between spare parts and left over parts.
Originally posted by The Metal Butcher View PostI was asking my professor a question at his office today, and when leaving I commented on his fresh McMaster 126 that just showed up. He said "Want it? Take it, I do it all online now." So now I have a brand new McMaster 126. I should have asked about the grainger catalog thereas well since their site is much worse, but I didn't want to be greedy.
