USA Maryland 21030
👍 1
While working on my shed today, I heard a loud noise, and when I went to investigate, I found this at the north corner of my property:
It's a brand new 2020 Toyota Tundra:
Yeah, I think he found out that there are limits to the off-road capabilities of the Toyota Tundra
The roll-back truck couldn't extricate the wreck:
So they called in the big hook wrecker:
http://enginuitysystems.com/pix/hous...Ditch_6138.AVI
http://enginuitysystems.com/pix/hous...Ditch_6139.AVI
The driver was about 25 years of age, and he was not injured, but he was close to tears about his new truck. The 2020 Toyota Tundra has an MSRP of $33k-$53k. He asked the cops if they thought it was totaled, and, of course, they said it was. I guess he thought a few cans of bondo and it would buff right out! He claimed that somebody ran him off the road, but that seems unlikely. He was obviously coming up the road, probably speeding, and may have tried to pass someone going the speed limit (30 MPH) or turning into the driveway. Then perhaps another speedster was barreling down the road, and to avoid a head-on collision, he must have veered off through the guard rail and into the ditch full of big rocks.Last edited by PStechPaul; 02-19-2020, 11:53 PM.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
USA Maryland 21030
Name doesn't mean much now except for scrap value. Watch out buyers, it'l be back on the road in a few days with handling problems you will never be able to get cured.“I know lots of people who are educated far beyond their intelligence”
Lewis Grizzard
Metal can be replaced or repaired
thankfully he is ok
Got hydraulics working on the Stratton
Now some parts to make (arms/top link)
According to the Brochure For the lift the installation is 14 hours. I’d say that’s reasonably accurate (although I had to make a lot of new parts and rebuild the pump which slowed me down.)
That dashboard looks real familiar... I have a 1991 YJ myself, mostly stock. Still going too, with 280K miles, 4-banger 5-spd.
I continues re-assembling the little 7x10, everything is working smoothly so far. Had to order the 3/8-20 LH tap, got the cross-slide nut tapped, had to make a new swivel plate to go under the compound. Files, hacksaw, taps. Got the bottom of the compound on, set at 30 deg and it locks up nice and solid when I get down on the screws. Progress! Still have to get the top on, fabricate a spacer and a washer, figure out how I'm going to mount the toolpost, adjust the gibs. It'll be done sometime this weekend. It will be nice to have a power tool again.25 miles north of Buffalo NY, USA
I bought a cheap Harbor Freight grease gun today ($9.99 and then 20% off) to modify to an oil gun for my Bridgeport. Really just removed the plunger and cut the bottom off so I could turn it upside and fill it with way oil. Not my original idea and some folks welded fancy bases on theirs so it could stand up and not leak. I think I will just store mine in a yam can.
The previous owner of the mill had pumped grease into the zerks instead of oil and I was afraid I was going to have to remove the table to clear the oil lines but I was able to get oil to flow through all the zerks and out the "seams." I wiped the grease of all the ways and they all now have a nice coat of oil so I think I am good to go for now.
👍 2
Finally got the 7x10 back together and working decently. Much thanks to Danlb for parts! Had to make a few misc parts and its interesting when you have no functioning compound or toolpost... so it made its own toolpost stud, a couple of spacers, a couple of screws, and modified some other screws. I used a angle gauge block to set the compound at 30 deg and locked it down. The compound swivel plate itself is hand made, out of some scrap A36 structural with just saw, files, and taps. Took a carbide scribe and scribed alongside the compound on the top of the cross-slide. That'll make it much easier to setup if I ever move it, but most of the time I just leave it at 30.
Tomorrow I have to adjust the gibs, the backlash on the cross slide, and give it a good cleaning and oiling. However in my limited trials so far it feels nice and solid -- things lock down and stay put when they should.Last edited by nickel-city-fab; 02-21-2020, 11:48 PM.25 miles north of Buffalo NY, USA
Originally posted by nickel-city-fab View PostFinally got the 7x10 back together and working decently. Much thanks to Danlb for parts! Had to make a few misc parts and its interesting when you have no functioning compound or toolpost... so it made its own toolpost stud, a couple of spacers, a couple of screws, and modified some other screws. I used a angle gauge block to set the compound at 30 deg and locked it down. The compound swivel plate itself is hand made, out of some scrap A36 structural with just saw, files, and taps. Took a carbide scribe and scribed alongside the compound on the top of the cross-slide. That'll make it much easier to setup if I ever move it, but most of the time I just leave it at 30.
DanAt the end of the project, there is a profound difference between spare parts and left over parts.
Originally posted by danlb View Post
Sounds great. Are pictures in store?
Dan
Previously, the cross slide had been butchered and the screws bent. Half of the compound parts were missing and the slides were bound up tight. However, there is almost zero wear on the ways. I had to make a swivel plate from scratch, and a few spacers. Got some screws and nuts at the hardware and modified them to suit. Made a toolpost stud. As usual the design isn't the greatest but its OK for small parts and can pull you out of a jam. You have to be careful how far you back off the compound -- not a lot of surface area, and needs more gib screws.
Future plans are 4-jaw independent chuck, and a MT2 dead center for the tailstock so I can have some bed length.
