Those boulders are everywhere in the natural landscape. They where here when I got here and this plot was forested, we moved them a little. It's a leftover from the last ice age. If you start digging anywhere in the soil in Finland, chances are you will strike anything from relatively small stones to large hidden bouders.
Downspout drop was plugged up with leaves and the gutter overflowed when it rains. Rather than put up a ladder and climb up there, I take the downspout apart and use a leaf blower to blow up the downspout. This dislodges the leaves and the built up water in the gutter then flushes the the debris out. It does result in a bit of a shower. When I installed the downspouts I used a fastener that I can just unscrew with one screw to take the downspout apart.
Originally posted by Ridgerunner View PostDownspout drop was plugged up with leaves and the gutter overflowed when it rains. Rather than put up a ladder and climb up there, I take the downspout apart and use a leaf blower to blow up the downspout. This dislodges the leaves and the built up water in the gutter then flushes the the debris out. It does result in a bit of a shower. When I installed the downspouts I used a fastener that I can just unscrew with one screw to take the downspout apart.
Originally posted by DennisCA View PostThose boulders are everywhere in the natural landscape. They where here when I got here and this plot was forested, we moved them a little. It's a leftover from the last ice age. If you start digging anywhere in the soil in Finland, chances are you will strike anything from relatively small stones to large hidden bouders.
- Likes 2
My high current AC source. 30A continuous, and up to 60A short term.
For higher than that, multiple turns. Clamp on one wire, read 40 A, clamp on two turns, read 80A, and so on. I usually do not need more than 10X, so 10 turns.
You need to be careful, because the position of the wire, and the size of the wire relative to the clamp-on ring can make a difference. Usually not too large, but if you are going for precision, it can matter.
I DO have an ancient "Columbia instruments" meter that will read AC or DC up to several hundred amps with no power source in the meter. It is a moving vane type.
And I have on the list for repair, a small meter that will read DC amps, but it requires a mercury battery that is not available anymore. I need to make a micro-power regulator for it that gives the correct stable voltage from an available battery type.
Originally posted by dian View Post
so your source is more accurate than the meter? you had to calibrate it somehow, no?
- Likes 1
Much faster than getting an extension ladder out and moving it around, especially when the house has sloped ground around it, and garden areas, right where the bottom of the ladder needs to go. I can walk around with that and do the job quickly.
Part of the guttering, which is old time copper gutter, I have put the open-cell foam gutter protector in. That works quite well, that part of the system no longer causes trouble. It probably helps that both of the big trees near the house had to be cut down because they were starting to drop limbs. One ancient maple, and an oak which had a 6 foot diameter stump. The oak dropped leaves, and in the spring, that "oak chenille", and the maple dropped many thousands of seed whirlies as well as fall leaves. There is still one maple on the south side, plus a pine.CNC machines only go through the motions.
I did the reverse, I made a PVC extension pipe that screws together and has a nozzle on it that can be moved to different positions. I attach the hose to the bottom, and use the nozzle on the top end to blast clogs down the pipe, and blast clogs in the gutter out of it or down the pipe as well.
Originally posted by bborr01 View Post
Your chimney looks damaged near the top. Did someone replace the furnace without adding a liner to the chimney? I did that and my chimney did the same thing. Natural gas and LP gas have a lot of moisture in them when they burn and the chimney will get wet and then freeze and pop the face brick off. You might be able to save whats left of it by adding a liner if that's the case.
Originally posted by Stu View PostSpent some shop time shortening my old Pexto slip roller from 30” to 13”. It resides on the floor and only comes up when needed. It was just getting too heavy to lift, plus in the 50 years I've owned it I never needed more than 12". The cut off parts weighed 39 lbs. Stu[/FONT]Still got those cut offs? lol.
