Originally posted by Tim Clarke View PostMade good progress sorting the metal stock here in the shop.
I got a flu shot today, on advice from my dr. It was free at the local grocery store. It's the first year that I've gotten the "old folks" version. Now I'm feeling old.
But I also picked up an emergency alert pendant for my mom. Got it working and will mail it to her tomorrow. I don't need one of those. Now I feel younger.
DanAt the end of the project, there is a profound difference between spare parts and left over parts.
- Likes 1
Originally posted by Bob Engelhardt View Post
Those are interesting. Do they evaporate/disappear so you know when to replace them? McM-C has equivalent (?) pads that you can buy one at a time, I think I'll try one.
https://www.mcmaster.com/78125T24/
There are a lot of different technologies out there in the field of Volatile Corrosion Inhibitors.
This might be closer to home for you: https://www.protectivepackaging.net/...ion-inhibitors
added a bunch of cheap one way valves to the one shot oiling system on my 6x26 mill. Before it was more like "5-shots to get enough oil to one place and 5x the amount to all the others" oiling system, as oil would drain back out of the tubes into the reservoir when not in use. Works a treat now, one pump is enough to oil all the dovetails. Looks like one side of the knee isn't getting much, so looks like I'll need to take it off and see what's going on.
Video of the forge, just drying it out after rain with some charcoal, full blast is too much air but it heats it well.
https://i.imgur.com/70BVMSR.mp4
Put up the formed pipe frame and moved the one solar panel to it. Project #1 for the "pipe squasher" done.
Next part is to put 4 more up on the old frame base, and install a new charger. I decided I was not going to get around to making a new SMPS type charger, so I just bought one. Did not like the first one, so there is another one coming in shortly.
All the panels are of similar current, so they are going in series, with a "buck regulator" type charger, which is more efficient than the old analog charger which had them in parallel.
4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
- Likes 1
Neither the old nor the new are MPPT, but set voltage. But they will do better than what was before. Big upchage for MPPT. The one in there now was a cheaper one that it turns out did not display charge current, which I want to see, so I am replacing that one as soon as the new one comes in. The better one also has a couple other features that I want as well.
We'll see when the rest of the panels get installed, if I get sufficient charging current per my figuring of the ratios, I am not going to worry about it for a while. I can go up to almost 60V of panels, and 30A charge current with the new one, so.......
The next step is several hundred bucks, for MPPT, 120V panel input, and 60A.... this setup does not need that yet.Last edited by J Tiers; 09-16-2020, 04:13 PM.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
Posted my "work wanted" ad on PM.
https://www.practicalmachinist.com/v...2/#post3624052
By all means please pass it on if you know anyone in my area -- thanks!25 miles north of Buffalo NY, USA
- Likes 1
Started at 2 am.
Spent a leisurely day with a good pal, former refinery crew mate, for the 1st time in 8 months.
Rode shotgun on a trip to his hunting lease. Moved 750 pounds of feed corn Into a feeder hopper.
Saw my first real fire ant colony.
Found out Wendy’s has passable Biscuits & Gravy on their breakfast menu.
Traveled 648 miles.
Arrived back home at 2:30 pm, dog tired and played with my grandson.Illigitimi non Carborundum 😎
- Likes 2
