I finished assembling my Clausing Horizontal Mill. I replaced all the belts and the hose that operates the Reeves Drive. It is like a new machine no belt slippage just quiet with everything working as it should. It will be put to work machining some Gooseneck Dies for my home made Press Brake.
I drove up to Minnesota, and found that the "snow showers" were actually a near blizzard on 35 N, with vehicles in the ditch and a road that was a mess. UGH.2801 3147 6749 8779 4900 4900 4900
It's just a box of rain, I don't know who put it there.
And are illegal here. We had them 50 years ago, and they tore up the roads.
I noted the same in Germany once when I bought a car from there and drove it home, planned to buy tires for the winter but could not get studded tires because they where illegal, fine for them down south I guess, so I had to order them from a finnish company and as we came off the boat in Hangö from Rostock in a january snowstorm that guy came in his van late at night and helped us change the tires on the car so we could drive the 450km up north without ending up in a ditch.
- 1 like
it's more the idiots who grind them into the pavement trying to drive out of a hole in the ice.... they DO get out, by grinding the ice away, and also the road.....2801 3147 6749 8779 4900 4900 4900
There are also probably some yahoos that thought it was fun and cool to burn rubber (and asphalt) on dry roads with the studded tires. If conditions are bad enough for studded tires, just get a good set of chains and you can be "king of the road". You may be limited to about 30 MPH, but you'll sure get where you need to go.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
In the north of the country (where I happen to be right now) there is plenty of snow and ice, and low temps, that may not get above zero F for weeks. But there are also plows, so things do not get too bad.
Driving up here, I only saw one plow on the interstate (Federal) highway, however..... the rest was a mess.2801 3147 6749 8779 4900 4900 4900
Originally posted by PStechPaul View PostThere are also probably some yahoos that thought it was fun and cool to burn rubber (and asphalt) on dry roads with the studded tires. If conditions are bad enough for studded tires, just get a good set of chains and you can be "king of the road". You may be limited to about 30 MPH, but you'll sure get where you need to go.
Roads are plowed, but not always in time and even when plowed, the roads over time develop a thick and solid layer of compacted snow, salting won't even work then and sand or fine gravel is deployed to help. And sometimes when it has been cold and it thaws and you get slick ice on the road studded tires work the best.
Originally posted by DennisCA View Post
........ And sometimes when it has been cold and it thaws and you get slick ice on the road studded tires work the best.
Ice is a bigger problem south of here, back where I now live.2801 3147 6749 8779 4900 4900 4900
Made a new mobile base for drum sander; also refurbished the drum sander (new switch and etc). Designed the mobile base so I can raise it to my table saw height to act as a receiving table.
I can't get the feeder belt to track; tried everything, today, I will check to see if the rollers are parallel and if the table is square. any suggestions?
A couple of days ago I did probably the best cold bluing job I've done yet on a piece of mysteralloy. Lovely dark and even black it was. Yesterday it rained quite heavily. Today I have evidence this provides no rust-proofing whatsoever - worse than leaving it bare to be honest. Left outside and covered in orange rust. Hammerite next, I think.
Passed 1000 youtube subs and 250 on instagram. I really need to make some new content.
Looks like I might be claiming the Daowoo 20x60 at work as "mine". Or at least have it be off-limits for graphite. Seems like a really nice lathe, but need some desperate cleaning, oiling, and some repair. Apparently it has a ball-screw leadscrew. How does that even work? I'll have to grab the manual and read through it.
